Old 04-17-2005, 08:28 PM
6ballsisall's Avatar
Boat: None this week!
Ignition Coil???
I put a Mallory Ignition Coil on my boat recently and sometimes, it gets extremely hot, expecially if the key gets left in the on position. Is this normal??? Help!
MC's owned:
1986 Skier 19
1995 ProStar 190
2003 X-7
1994 ProStar 205 (current)
Old 04-18-2005, 02:32 AM
tph's Avatar
tph tph is offline
gnition
My Accel Coil got too hot to touch after I installed a Pertronix electronic ignition. I called Accel and they told me that the coil I was using was not recommended for use with electronic ignition. I replaced it with a Pertronix flamethrower and that seems to work better, though it still got warmer than when using the stock ignition set-up. The impedence of the flamethrower was different and I eliminated the ballast resistor. Also, the instructions warned that damage could occure to the ignition system if the key was left in the "on" position.
Old 04-18-2005, 07:02 AM
jsonova99's Avatar
jsonova99 jsonova99 is offline
Boat: 1991 Mastercraft Prostar 190
that sounds like it could be dangerous
1991 Prostar 190 - Ambush 4 blade prop
Old 04-18-2005, 09:12 AM
Seems I recall the Pertronix FlameThrower II addressed the "key left on" issue?
Duh, actually its the electronic module NOT the coil sensing the "key on" deal, so if you go with the Igniter II, you're OK? - that's what the propaganda suggests...
Wes
