Old 06-25-2008, 07:54 AM
Skipper
Posts: n/a
Clunky Transmission in Neutral
The issue:
In neutral, at idle, the transmission produces some clunking noises and the shaft spins very slowly. No problem shifting, accelerating, holding speed, or decelerating.
The boat:
1995 Prostar 197, standard EFI engine, 1:1 transmission, 520 hrs.
I suspect I am in need of a rebuild. My previous experience is limited to Velvet Drive transmissions. Any ideas?
Old 06-25-2008, 08:40 AM
trickskier's Avatar
trickskier trickskier is offline
Boat: 2006 X-1 MCX
Does your shaft have a keyway in it?
The Only Thing That You Can Give and Still Keep Is Your Word
Old 06-25-2008, 09:40 AM
Skipper
Posts: n/a
Yes, no issues with the driveshaft from prop to coupling.
Old 06-25-2008, 02:48 PM
Hunterb Hunterb is offline
Boat: 1990 Prostar 190 351
The slow spinning shaft is fairly common and not necessarily a sign of a transmission problem. The clunking may be your damper plate. It's the thing that goes between the flywheel and the transmission and it has a number of springs etc. in it. They are inclined to make funny noises at idle sometimes. Unfortunately you have to remove the tranny to check it. I would look very closely at that before I had the tranny re-built.
Bruce
1990 Prostar 190, 351 Indmar SO, bought as an empty shell and rebuilt over the winter (04/05). Sold in May 2009
New boat - 1993 Prostar 205. Bought in better shape than the 190 was but still needed some work.
Old 06-25-2008, 03:15 PM
kawagaskier's Avatar
kawagaskier kawagaskier is offline
Boat: MasterCraft, Stars and Stripes, 1985, 351W, Powerslot
It only does this in neutral? I had a similar problem with my 85 S&S, but in gear at idle. Turned out my idle speed was a little low. I adjusted the idle up to about 750rpm and the clunk was gone.
Old 06-25-2008, 03:52 PM
Much2do Much2do is offline
Boat: Mastercraft, Prostar 190, 1988
Is the clunk heard when you shift into gear or while you at idle idle out of gear?
If it's simply an excessive clunk shifting into gear then replacing your transmission fluid may solve it.
Old 06-25-2008, 03:56 PM
trickskier's Avatar
Boat: 2006 X-1 MCX
If it's making a ticking noise, then the keyway is going bad. My 82' had this same problem and the driveshaft finally came out hitting the rudder and damaging the prop........I had to replace the shaft & the prop.
Pull the shaft and inspect the keyway area.
Old 06-26-2008, 05:28 AM
Skipper
Posts: n/a
Not an idle issue, in fact the idle is a little high.
Old 06-26-2008, 05:29 AM
Skipper
Posts: n/a
Not really making a clunk when I shift. The shift is just fine. It is just that when the engine is idling there is excessive clunking or rattling noise coming from the transmission. I change the engine oil and transmission fluid every 25 hrs.
Old 06-26-2008, 05:31 AM
Skipper
Posts: n/a
Not really a ticking noise.
