Old 06-25-2008, 03:47 PM
JDAVIS9007
2002 Predator Impeller Housing
I own a 2002 Pro Star 190 and the impeller housing is not perfectly round to say the least. The right side is flat and the impeller drags. I have had overheating problems ever since I bought the boat but it is used so rarley this is the first time I checked the impeller
Should the housing be a perfect circle?
Old 06-25-2008, 04:09 PM
bmeth11's Avatar
bmeth11 bmeth11 is offline
Boat: 1997 Mastercraft Prostar LT1 190
my impellar housing isn't a perfect circle if i remember correctly... or atlease its a little tighter on one side than the other...
Old 06-25-2008, 04:10 PM
thijs's Avatar
thijs thijs is offline
Boat: Malibu Response LX 1999 Monsoon 325
No it shouldn't be perfectly round. Pictures would help to make sure I am thinking what you are, but this is how it is designed.
Now: 1999 Malibu Response LX Monsoon 325
Past:1994 MasterCraft Prostar 205
Old 06-25-2008, 04:49 PM
dsoby's Avatar
dsoby dsoby is offline
Boat: 2002 X7, LTR
The flat part is what creates the suction for the pump to work properly. If your boat is overheating, there are many possible causes. Start by checking the intake side of the transmission cooler for obstruction. Replace the impeller (johnson 612 probably), and check your thermostat.
Old 06-25-2008, 04:51 PM
When did you buy the boat and what has been done to try to fix the problem? If the impeller has been changed without changing the gasket, that can cause the raw water pump to suck air, which doesn't work as a coolant very well.
Johnson 812, not 612.
Old 06-25-2008, 04:52 PM
dsoby's Avatar
Boat: 2002 X7, LTR
812, thanks JimN
Old 06-25-2008, 04:53 PM
Sodar's Avatar
Sodar Sodar is offline
Boat: '07 ProStar 197 w/ MCX
You guys are talking about IMPELLERS!! This guy is talking about IMPELLAS!! Get with it, would ya!
-Cameron
2007 ProStar 197
1996 ProStar 190
bigmac bigmac is offline
Boat: 2004 Maristar 230 VRS
Originally Posted by JDAVIS9007 View Post
I own a 2002 Pro Star 190 and the impella housing is not perfectly round to say the least. The right side is flat and the impella drags. I have had overheating problems ever since I bought the boat but it is used so rarley this is the first time I checked the impella.
No, the eccentricity of the housing is what makes it work.
'04 MariStar 230VRS/MCX
Old 06-26-2008, 08:05 AM
kjohnson's Avatar
kjohnson kjohnson is offline
TT Hero
Boat: 1991 Prostar 190
Impella
Isn't an Impella an animal that roams the African plains? No I guess that is an Impala. So what is an Impella? Is that ebonics for impeller?
Love my boat, hate my trailer.
impeller
