Old 07-25-2008, 03:54 PM
Muttley's Avatar
Muttley Muttley is offline
Boat: 1992 Prostar 205
Originally Posted by nwhittuk10 View Post
Hey Muttley where exactly could I find the gas tank at?
On my '92, you lift the rear seat out, then pull out the reamining rear panel from the bottom. The sending unit will be on the top of the tank toward the port side.
Originally Posted by bigpack20 View Post
My fuel gauge will go to full but when I run the baot it will not go below 1/2 tank. would that be a sending unit. Were would the sending unit be on a 1998 pro star 205???
Thanks for the help!
I'd still say it's the same thing. On mine, the slider ridges inside the tube were slightly warped. That's why I had to sand out the grooves in the float. Your's may be warped at the 1/2 way point not allowing the float to go all the way to the bottom. I believe the '98 tank is similar, but you may need to remove the vent and filler hoses.
Some mornings it just doesn't seem worth it to gnaw through the leather straps. -Emo Phillips
Old 07-25-2008, 07:50 PM
bigpack20's Avatar
bigpack20 bigpack20 is offline
Boat: 1998 Mastercraft Prostar 205
Thanks for all the info
Old 07-26-2008, 09:49 AM
gguppy gguppy is offline
Boat: mastercraft,205 prostar,1992,351
thanks for the advice (Muttley) this work perfectly. This wed site is the best!!!!!!!! Note at the top of the sender i saw that it is begin to crack, i guest that i will have to replace soon, but for now its is working. Thank for now.
Old 08-14-2008, 09:05 AM
WishIWasSkiing WishIWasSkiing is offline
Boat: 1996 Mastercraft Prostar 205
I've got a 96 PS205 that's new to me, & the fuel gauge was stuck at 7/8 full. I figured it'd be the stuck float in the sending unit, but it slides freely. Then I thought it might be a bad ground - nope. When the key is turned to off, the gauge goes down to E like it should, & pops up to 7/8 when key is on. Could it be a bad gauge? Anyone else have any non-stuck-float-in-the-sending-unit problems/solutions?
Old 08-14-2008, 09:23 AM
Did the float have two small magnets on it? If not, they're probably on the circuit board, close to the top. The gel type super glue works pretty well.
Old 08-14-2008, 01:10 PM
Yes, the magnets were in place. I even bought the gasoline resistant glue figuring they'd be dislodged or they'd get dislodged in the sanding process.
Old 08-14-2008, 01:18 PM
coz's Avatar
coz coz is offline
Boat: 1998 ProStar 205
Here's what I did http://www.mastercraft.com/teamtalk/...ad.php?t=21325
Old 08-14-2008, 03:16 PM
Turn the key to ON and watch the gauge, then disconnect the pink wire. If it stays there, disconnect it from the gauge and see if that makes any difference. If the pink is off of the gauge and it still goes to 7/8, it's a bad gauge. If you connect the two wires on the sender, the gauge should go to FULL.
Old 04-26-2010, 01:45 PM
jomiddour jomiddour is offline
Boat: Mastercraft, Prostar 190, 1991, 351w
Would I need to remove the gas tank to access the sender or can it be removed from the top of the tank while its still in place?
Thanks!
Old 04-26-2010, 03:18 PM
Chicago190's Avatar
Chicago190 Chicago190 is offline
Boat: Mastercraft, Prostar 190, 1996, 285 HP
Thanks!
What year and model?
1996 Prostar 190, 350 TBI and Powerslot
