Old 06-18-2008, 01:08 PM
capt capt is offline
Boat: 1982 stars & stripes, 351 pcm
Transmission lines and oil cooler
on my 82 Stars & Stripes, Borg Warner 1 to 1:52 transmission which line goes into the top fitting on the oil cooler and which one goes on the bottom fitting? I got the bottom line on the transmission going into the bottom fitting and the top tranny line going into the top fitting. Is this correct? next time I'll take a picture.
Old 06-18-2008, 02:42 PM
TMCNo1 TMCNo1 is offline
Boat: Gone
The (longest) line closest to the raw water inlet end of the transmission cooler goes to the bottom of the transmission and the (shortest) line closest to the outlet end of the transmission cooler goes to the top of the transmission.
Charter Member Number 1
Quote: 2RLAKE,
Old 06-18-2008, 04:05 PM
Let me make sure. The shortest transmission line goes into the top of the transmission. the longer line goes into the under right side. now which one goes into the top of the oil cooler? thanks
Old 06-18-2008, 04:17 PM
JLeuck64's Avatar
JLeuck64 JLeuck64 is offline
Boat: 98 Prostar 190 Stars & Stripes, LT1
Where the lines reach the best is where they should go. In other words it doesn't really matter which direction the fluid flows through the cooler. As long as the circuit is complete you will achieve cool-ness
Need LT-1 parts?
89058397 (pump outlet side)
Old 06-18-2008, 04:26 PM
Boat: Gone
The line (the long one) closest to the raw water inlet end of the transmission cooler goes to the bottom of the transmission and the line (the short one) closest to the outlet end of the transmission cooler goes to the top of the transmission, this is regardless of whether it is vertical or horizontal and I don't know how yours is placed to know which end is on top.
A picture of the cooler hooked properly to the raw water hose from the pickup on the bottom and to the raw water pump would be helpful, but the end with the hose hooked to the bottom pickup is the inlet end and the other is the outlet on the side of the raw water pump.
Old 06-27-2008, 06:33 PM
denverd1's Avatar
denverd1 denverd1 is offline
Boat: 1986 Tristar 220, 351W, 2000 lbs
so criss-cross them is best, but it doesn't matter. top to bottom, bottom to top.
mine is oppo, but the coolness must have been there, cuz no problems in several yrs.
