Old 06-13-2008, 08:26 AM
jasonwarda11 jasonwarda11 is offline
Boat: 1982 19 skier ford 351
Help my Boat wont start!
so I have a 1982 19 skier, with a ford 351, holley carb. The Boat starts great when i get to the lake. after running for a couple of hours (totally fine) ill shut the engine off to swim/relax maybe 30 min. then it wont start. engine will roll over but not fire. I went through all the carburator issues and that didnt help. Yesterday I brought a spark tester with me....there is no spark. The cap, rotor, and wires are new. It will only do it when the engine is hott...and if I wait for 20 min or so I can usually get it started again.....what do I do????
thanks a lot for your help!
Old 06-13-2008, 08:36 AM
TMCNo1 TMCNo1 is offline
Boat: Gone
Check the kill switch!
Charter Member Number 1
Quote: 2RLAKE,
Old 06-13-2008, 09:00 AM
Slinkyredfoot's Avatar
Slinkyredfoot Slinkyredfoot is offline
Boat: 1979 Mastercraft, 1998 ProStar 205
Does your engine still have breaker points in the distributor?
Several years ago before I changed mine out to breakerless, my 79 experienced the same symptoms you are dealing with. The points were pitted and burned, changed them out and the boat started fine after that.....
If for some reason you start to believe you are a person with influence, just try ordering somebody else's dog around.
Old 06-13-2008, 10:05 AM
i saw something online about the ignition module going bad on these engines? any thoughts to that??
Old 06-13-2008, 10:32 AM
wakeX2wake's Avatar
Boat: 2007 mastercraft x2
could be... electrical probelms do tend to worse when hot due to expansion of metals (namely Cu) and reduced electrical contact... far from an expert here though i just know a little about metals
MY WAKESIDE RIDE
-Parks Bonifay
-Frank Sinatra
-Jimmy Buffett
Old 06-13-2008, 10:52 AM
Boat: Gone
That may be true if you have an electronic ignition conversion kit, but otherwise the points may be stuck/corroded or common gasoline vaporlock!
Old 06-13-2008, 02:03 PM
Jim@BAWS's Avatar
Jim@BAWS Jim@BAWS is offline
What you are experiencing is VAPOR LOCK. If your FUEL SEPERATOR is mounted close to the motor it allowing the fuel to be heated. Rerun the FUEL LINE from the tank to the fuel pump. Mount the FUEL SEPERATOR on the side of the tank if possible. There is an EXTRA FLANGE on the drivers side upper part of the tank.
If you cannot do this...as soon as you are done driving the boat allow it to cool under idle. Do not kill the motor just after a hard ski run (HIGH RPM) Lift the motor box immedialty so the motor can cool faster. Then restart.
I have seen this happen alot in older boats.
Lets us know what happens
Jim@BAWS
Tampa Bay's Exclusive MasterCraft Dealer
www.BAYAREAWATERSPORTS.com
(813) 996-BAWS (2297)
Old 06-13-2008, 02:15 PM
Hollywood's Avatar
Hollywood Hollywood is offline
Boat: MasterCraft, ProStar 209, 2003, MCX
I don't think it's fuel related.
Old 06-13-2008, 02:43 PM
Boat: Gone
We really need a expert opinion on this, have you been doing powerturns, http://www.tmcowners.com/teamtalk/sh...02&postcount=9
Old 06-13-2008, 03:28 PM
NU-skier's Avatar
NU-skier NU-skier is offline
Boat: 1998 Prostar 205, Husker Red & Black, purchased Jan 98
Send a message via AIM to NU-skier
No spark when hot sounds like a bad coil.
They work again when they cool off. Soon it will not work at all.
