Blower placement
Hi everyone,
I am progressing with the rebuilding of my 1990 PS 190. One of the parts I got with the boat that was in the big box of parts is the blower. I know it goes under the floor somewhere and then a hose connects it to the vent opening by the left exhaust hose, but I don't know where the blower unit itself is normally positioned. Is there a 'best spot' to put it? Also, would you normally have any hose coming off the 'intake side' of the blower or does that depend of where you mount it? Any suggestions would be appreciated. Thanks Bruce |
Hunter, mine is located on the starboard side of the engine (a bit underneath the engine about midway back). The hose runs straight back along the inside of the starboard exhaust pipe. Hopefully, this picture will help. I lightened it up a bit so you could see the hose. Obviously, the blower isn't visible, but it's connected to the front of the hose.
Previous: 1993 Prostar 205 Red 1998 Ski Nautique, PCM GT40, 310 hp, , Acme 4 blade, Perfect Pass SG/Zbox. FAQ Be kind. Have fun. Last edited by east tx skier; 04-14-2005 at 05:33 PM. |
John 3:16-18
You sure Sporty? Seems like it would be absolutely necessary to vent the engine area as the carb (in this case) will be the most likely place gas fumes will come from.
On my '94 their down by the stringer under the engine. In fact, I believe they might be using the same bolts as the motor mounts.
- Bill -former '94 PS205 owner. Still ridin my Sky Ski..... Last edited by AirJunky; 04-14-2005 at 06:31 PM. |
John 3:16-18
John 3:16-18
#7
In the older boats the blower itself is mounted above the gas tank as in Sporty's photo. But the hose runs down behind the tank to the bilge. This causes the air to be pulled into the bilge from the front intake, run under the motor box, and then gets sucked out the back by the blower motor. Many boats have this design and most blowers move some serious air so I think this would work fine.
But since the boat in question is different than mine I'd figure out where the blower and hoses are normally for that exact year. I'm sure the answer will be posted shortly.
Scott FitzGerald 1984 Stars & Stripes w/454 |
#8
Man, that sucks!
#9
Mine is run just like tex, and Air junky. Under the engine.
The hose runs back to the vents at the back of the boat. The blower motors are water resistant. The way mine is mounted, the floater switch will kick on the bilge pump before water gets high enough to get to the blower motor. Hope this helps
"Let me not pray to be sheltered from dangers, but to be fearless when facing them." 1999 X-star, 330 LTR, Zero FLex tower. |
#10
Thanks for all the replies and pictures. I think I will try to secure it on the drivers side of the motor and run the hose along the exhaust pipe as in the picture from east tx skier. I think it's probably more efficient to have the blower pushing air rather than pulling it.
Thanks again for the replies. I'm sure I will have more questions as I put this boat back together. Bruce |
Thread Tools | |
Display Modes | |
