New 2008 X30 is great but......
Yo people, im new to these forum so a big hello to everyone. Ok we have purchased a X30 and boy we are happy with it but we have one problem. The audio hums and the dealer cant sort it. They have tryed but it always comes back as soon as we take the boat. It's tone will change with the engine rpm and im wondering if this is a common problem on 2008 mastercrafts? My friends 2008 xstar dont do it and it has the exact same audio package.
Here she is ![]() Last edited by Barritia; 06-11-2008 at 08:25 AM. |
Sounds like the amp isn't grounded exactly right because you getting engine noise in your speakers... Where is it grounded? Beautiful boat and welcome.
1996 Maristar 225 VRS
Thanks for the reply Odyssey. I am about to check the wireing today so i will check the amp ground as im sure it's something simple. Will post back later if i find the problem.
I had that same problem in my car.. I never did fix it...
Chris Reasner Co-Founder / Sales Manager Growth Studios, Web Development Company www.growthstudios.net |
Ground problem...
Check to make sure that all of your audio system is using a common ground.
If my words don't make sense, try reading them backwards. |
Amplifier
Check with your dealer. we had the same issue with a 2008 X2 and it was a Bad grounded Amplifier but inside the unit itself, we replaced the amplifier and problem was fixed.
Your dealer will gladly take care of this.
Bennett's Boat & Ski Bennett's wakeboard & waterski school sales@skibennetts.com 1.800.869.7297225.654.9306
#7
Check your speaker wires make sure they are not running along side any power cables and it wont hurt to get them away from your Pre-amp output cables running to your amp. I believe the JL amp instructions say to only cross them and not to run them together.
Good Looking boat. I like the wrap and color combo on the interior.
2006, X-45, Acme 1285, X-Star ballast, Heater, Shower, Last edited by endl; 06-11-2008 at 10:37 AM. |
#8
Welcome
I am jumping on the bad ground bandwagon, check all your amps for a common ground If you still have the problems?? have the dealer switch out your amp
I rather be waterboarding
#9
"Call on God, but row away from the rocks"- Dr.Hunter S. Thompson
#10
"same issue with a 2008 X2 and it was a Bad grounded Amplifier but inside the unit itself"
Same here on an 08. Got it swapped also. Bad batch of amps? |
