Recommended Spares - suggestions?
Next week I'm heading out for my first long trip with the X2 MCX (two weeks at Shasta) and I don't want anything to spoil the fun. Looking for some suggestions on what spare parts to keep in the boat. Here is my list so far:
spark plugs spark plug wires fuel filter raw water impeller spare prop Any other suggestions? |
Impellers for the ballast pumps
fuses (stereo as well as look under the dash, there are a few inline fuses) Extra nut for the spare prop extra nuts and bolts such as bimini hinge pin, tower knobs hose clamps If your ballast system has any plastic fittings, I carry spares of those as well as a plug and a hose clamp that let me cap off any busted water line. I also carry an old standard bilge pump, over the side, silicon hose, cigarette lighter plug, type ballast pump in case the ballast system goes FUBAR
2003 ProStar 209, 2 flags, 8 cup holders Last edited by DanC; 06-06-2008 at 02:23 PM. |
I would recommend beer.
1989 Tristar 190 - Indmar 351, 250HP, 1:1, 450 hours |
Cool, thanks. Trust me the boat doesn't go anywhere without a full beer supply. Hmmm, a keg in the back corner might work well as surfing ballast...
A fresh tube of permatex gasket maker, roll of duct tape, zip ties and a new package of J. B. Weld
hey nice post. that reminds me, i should pick up a spare impeller. what do those run anyway, like $35 or so right?
sweet thanks!
Since you have an 07, I didn't include parts you should have for an older boat like points, belts, trailer wheel bearings...
I assumed you'd also get the tool list together (a spare prop isn't much help without a prop puller) Of course you would loose your man card if you didn't have duct tape and tie wraps ![]()
2003 ProStar 209, 2 flags, 8 cup holders |
i always take some electrical wire, wire crimper/cutter and some wire splices...never know when a wire could cut, burned or shorted
