1:1 velvet drive won't go into gear unless....
I posted about this a while back but can't seem to find the thread. Anyways, I never got around to fixing it but want to get it up and running for this summer. I was hoping you guys could give some ideas as to the problem and/or solution. Here are the details:
Indmar 351 - 1:1 Velvet Drive -Goes into reverse with no problem at all -Only goes into drive around 2,000rpm -After I have been driving for a while, then put it in neutral, then go back to drive it works perfect, but once I let it sit for a while the problem occurs again. -I checked the tranny fluid and levels are good. Color of the fluid looks good too. Any ideas what may be causing this? Thanks! |
The next thing I would be looking at would be the cable/linkage adjustment. Try disconnecting the shift cable from the linkage arm on the transmission. Then I would try shifting into forward gear, out in open water of course, to see if it engages any sooner. If it does then some adjustment is necessary. If it doesn't then we'll cross that bridge when we get to it.
http://www.mastercraft.com/photopost...er=2572&sort=1 Need LT-1 parts? OIL FILTER: Factory installed is a Penzoil P23, Afta market brands, AC Delco PF-454 and a Fram PH-13 or PH-30 will work. SPARK PLUGS: AC Delco MR43LTS (gapped to .040") FUEL FILTERS: AC Delco 25171391 (pump inlet side) 89058397 (pump outlet side) IGNITION WIRES: Call Inboard Online @ (877) 327-7175 and order part numbers 556010A (odd bank) and 556010B (even bank) |
Thanks, I will try to take it out ASAP and post what I find.
Thread Tools | |
Display Modes | |
