Engine Flush Device
I'm looking for a device to hook up a garden hose to the engine to flush it this spring before I put it in the water. My dealer uses a little connector that connects directly to the engine on one of the coolant hoses. I have also seen the plunger devices that attach to the bottom of the boat. Any thoughts on those? I have a '04 Prostar 197.
The one that looks like a plunger is a "Fake-a-Lake", I use one and think they work well.
OH-IO! |
I use rubber hose and clamp it to the raw water intake and the garden hose based on the advice of MYMC. Worked great.
'97 Prostar 190 - LT-1 Prior boats - 2009 X14, 2008 X14, 2005 197, 1988 Tristar 190, 1989 Prostar. |
http://www.foreandaftmarine.com/7-0418.htm
External flush connection for about twenty bucks. Use in conjunction with perko flush pro and you will never have to lift your engine cover to flush again.
2006 Maristar 200VRS MCX KGB Ballast and all the works! Tow Veh: 2010 Toyota Tundra Bike: 2007 HD Street Glide Beer:Sam Adams Boston Lager/ Cherry Wheat, Petes Strawberry Blonde, Petes Wicked Ale Chief Petty Officer: "Results not excuses" "You Can't Beat a Tree" |
I disconnect the raw water hose and put a long clear non crush type hose to the intake. I use a large drum and fill it with water and let the water run even while the engine is running. Never had a problem with it. JimN used that on our boat many moons ago and I use that method when ever I have to start the engine out of the water.
Flush Pro 1" or Flush Pro 1.25" installs in-line with the fresh water intake. It works well, $57 at www.skidm.com. You can also use it to suck aintifreeze out of a bucket for winterization. Installation beside/below the engine can be a bit tight. I marked the fresh water line, removed it from the boat before trying to squeeze the line on to the Flush Pro. Another tip, use a brass garden hose "quick connect" coupling to attach the hose.
If the bunks cover the intake like they do on my x10 the fake a lake will not work. What I put together is a ball valve on the intake side to shut off the intake and then connected to it running towards the engine a connection for a garden hose. I just dont trust the plastic on the flush pro, I think someone on here had theirs start leaking on them.
_________________________________ 2004 X10 Predator 5.7L |
I have a few questions about this topic. where do you place the water inlet fitting / external flush connector on your boat? How long does the whole system take to install? Have there been many complaints about this system leaking? Thanks for any input.
PCM 351w, 350hp |
#10
