Old 05-26-2008, 08:18 PM
MajorJohnson's Avatar
MajorJohnson MajorJohnson is offline
Boat: 1989 Mastercraft Pro Star 190
How to get a prop off?
OK How in the heck do I get the prop off? The nut is removed and the prop will not move? Any suggestions?? THANKS
Old 05-26-2008, 08:21 PM
T Scott T Scott is offline
Boat: It's always changing! X-Star-Prostar190/205-Maristar
Usually you have to use a prop puller. Those suckers can really get on there tight!
Old 05-26-2008, 08:28 PM
Yeah mine is not budging guess its off to the dealer in the morning!
Old 05-26-2008, 08:33 PM
P-hat_in_Cincy's Avatar
P-hat_in_Cincy P-hat_in_Cincy is offline
Boat: MasterCraft Prostar 205V "wakeboard edition", 2004
I use a big 2 jaw gear puller.
I've heard of some people hitting the shaft with a rubber hammer, but I don't know the details or results.
Tip: Don't take the nut all the way off. Loosen it, but leave it on so when the prop pops off it slams against the nut rather than your hand and/or rudder.
2004 MasterCraft Prostar 205v 'Wakeboard Edition'
Old 05-26-2008, 08:58 PM
cdstukey's Avatar
cdstukey cdstukey is offline
Boat: '10 X-14v
Try adding a little heat, but be careful not to get the torch too close to your fiberglass. It will literally pop right off.
-Chad
2010 X-14v, 1995 CC Ski Nautique
previous
2001 MC Prostar 190,
1989 CC Ski Nautique 2001,
1984 CC Ski Nautique,
1979 CC Ski Tique
Old 05-26-2008, 08:59 PM
Willski's Avatar
Willski Willski is offline
Boat: 2008 x2
Yup. I usually have to use a puller on mine. They get tight on the taper shaft.
Old 05-26-2008, 09:13 PM
TMCNo1 TMCNo1 is offline
Boat: Gone
Prop puller, plenty WD40/PB Blaster and if that doesn't work, add heat from the high setting on a hair dryer or heat gun to the prop hub and it will "bing"!
Charter Member Number 1
Quote: 2RLAKE,
Old 05-26-2008, 10:20 PM
h2oskifreak's Avatar
h2oskifreak h2oskifreak is offline
Boat: 1994 PS 190 TBI
Lowes carries a "c" clamp w/ a forked end that will work for less $ than a prop puller.
"One foot in the grave, one foot on the pedal, I was born a rebel" Petty
Old 05-27-2008, 10:34 PM
Well I used the 2x4 gig and then I used the PB blaster then I used the lowes C clamp gig and the thing wont move!!! Should I use hair dryer gig then or take it and spend 100 bucks for the shop to take if off???
Old 05-28-2008, 12:05 AM
Boat: 1998 Maristar 200VRS
Put the C Clamp on, and tighten down as far as you dare. Get a 5-pound hammer, and hit the end of the C clamp. That did it for me.
Alternatively, there are plenty of special-purpose prop pullers out there. Search Ebay with "Prop Puller", or order from OJ or Acme. The C-clamp style are built stouter than what you probably have from Lowe's, and have appropriate threads to get a strong pull on the prop. Acme has a "harmonic prop puller" that works a bit differently.
Good luck.
/frank
