Old 05-14-2008, 01:54 PM
MDuncanAU MDuncanAU is offline
Boat: X-Star, 2007, LY6, 400HP, Black/Blue
Exclamation High pitch whining when engine slightly engaged
Hi I was wondering if any of you other MC owners have experienced a high pitch whining noise when you initially put the boat into gear. It sounds like it is coming from the drive train area. Anytime we are running 600-1300 RPM there is this constant whining noise. As soon as you start to pull up a skiier it goes away, but it is very annoying when just putting back to the downed skiier or when docking the boat. We use to have an '03 X-10 but have recently upgraded to an '07 X-Star (awesome boat by the way). The noise occurs in both boats. We thought it was just the X-10 but now that it is happening in the X-Star as well, we are beginning to believe it is a MC thing. Is this true? Can you get rid of it?
Thanks fellas
Old 05-14-2008, 01:59 PM
Maristar210's Avatar
Maristar210 Maristar210 is offline
Boat: paddle
Thanks fellas
I usually get a high pitched whining from Sodar upon entry, but once we get going it goes away.
Seriously - This is very common
Old 05-14-2008, 02:01 PM
jkski jkski is offline
The high pitch noise you hear may be the CNC prop "singing". The way that the prop is cut makes it do this and it does not go away. Another option could be your transmission. Not sure what the gear ratio is in your boat but a powerslot tranny for instance makes more noise than a 1:1.
Hope this helps.
Old 05-14-2008, 02:06 PM
TMCNo1 TMCNo1 is offline
Boat: Gone
You may also get a whining noise in neutral and in gear at idle if the raw waterpump impeller is worn and near needing replacement!
Charter Member Number 1
Quote: 2RLAKE,
Old 05-14-2008, 02:07 PM
Thanks for the quick replies guys. I hate to be "that guy" but what is Sodar? Our noise also goes away once the boat goes a little faster, but if we could get the noise to go away completely it would be nice. However, as long as it is nothing that is tearing into the transmission or anything then I am okay with that. I don't know if it is the gear ratio since it occured in both the X-10 and X-Star. Since both of you say that it is common and most likely not a problem then I can sleep a little better now.
Thanks
Old 05-14-2008, 02:49 PM
wakeX2wake's Avatar
Boat: 2007 mastercraft x2
Sodar is a modertor and slight instigator here on TT
MY WAKESIDE RIDE
-Parks Bonifay
-Frank Sinatra
-Jimmy Buffett
Old 05-14-2008, 02:52 PM
1boarder 1boarder is offline
Boat: 2008 X2, MCX
you don't have any in-laws in the boat do you. If you speed up you can't hear them.
Old 05-15-2008, 01:26 PM
h20_skidog's Avatar
h20_skidog h20_skidog is offline
Boat: Current 2015 X-10 | Previous 2001 Prostar 201
Yeah, that happened to me one spring...and I too thought it was a trans problem...however it did turn out to be the impleller!!
Check the simplest first!
Old 05-15-2008, 02:07 PM
jrhollow jrhollow is offline
Boat: 2003 Mastercraft X-2
Check to see if it is the bushing in the strut. When the boat is out of the water spray wd-40 on the drive shaft where it goes through the strut. If it stops for a while either you have a worn bushing or a bent strut.
Old 05-15-2008, 07:01 PM
Dottiesboat's Avatar
Dottiesboat Dottiesboat is offline
Boat: 99 PS 205 LTR
We had that problem also. Going thru the water at 1500-2200 RPM then to neutral there was a high pitched noise until the prop stopped turning or moving realitivly quickly through the water. It stopped a little bit before we lost steering ability as the boat slowed. I attributed the noise stopping to replacing the spark arrestor with a K&N unit. Our boat came from the dealer without an air cleaner.
The air cleaner was replaced in about 2001 and have not had the problem since. the impeller has worn out and benreplaced 2-3 times since also. She had about 150 hours in 2001, and has over 500 hours now with no high pitched whine since installation of air cleaner.
Boat is a 1999 PS 205
