Trailer Touch Ups
This turned into a bigger project than I was expecting. I decided not to take the trailer to be sand blasted and painted due to cost and lead time. Overall the main frame rails on the trailer look good but the prop gaurd and cross members had rusty spots at all of the low point. Also the brackets that hold the bunk boards were getting rusty. Needed new bunk carpet too. So since I do not pull the trailer many miles I decided to go ahead and do the bad areas myself. Grind off the rust, sand, prime and paint with Rustoleum. When the prep is done right the finish actually holds up really well. So here is a couple of interim pics.
1997 Prostar 190, TBI 350, 1:1, OJ XMP 13 x 11.5, Stargazer, Hot Shower, Heated Drivers Seat, Reuben/Mountain Rock/Nite Navy |
And the back which was in the worst shape.
Looks like a good start
go go go! |
Good work.
By the way, watch that v-block. When that composite stuff goes, and only the carpet is holding it, it can make some nasty gougest in the gel coat.
Does anyone know how to get the roller off? I can't figure it out. Just has what looks like two end caps on each end of the shaft.
#7
The roller is put on by push nuts. My push nuts were corroded on , so after messing with the for a long while, I just to a grinder took it and ended its misery. On the re-install, I got a peice of threaded stainless rod cut to length and used that with 2-stainless cap nuts... ended up looking very clean!
Good Luck! |
#8
Looks like you're well on your way.....looks good
Lots of power is good, more is better, too much is just right. ![]() '91 prostar 190 |
#9
looks like a nice start. Anyone know where you can get replacement MC logo stickers for the rear?
#10
I had a guy at my office make me new stickers. I can get you in touch with him you'd like.
KStateSkier "Le ore del mattino hanno l'oro in bocca" The morning hours are the most precious of the day! |
