Old 04-17-2008, 12:56 PM
coz's Avatar
coz coz is offline
Boat: 1998 ProStar 205
PSS Shaft Seal Question..?
Anyone have experience with these? I've had this boat a little while now and on my last one I would get no water in the bilge, even on a busy weekend (mercruiser) while on this one the shaft drip lets water into the boat, not alot but it still sloshes around and gets down into palces where noone's ever been before and can corrode. On a busy weekend it can get a good amount and the pump only takes out so much. This says does not leak water into the bilge. Anyone have this? or experience with it? Thanks
skidim part 1907
PSS Shaft Seal. The PSS shaft seal is a replacement system for stuffing boxes. The PSS has no packing to adjust or replace and does not leak water into the bilge. Additionally, due to the simple design, the PSS requires no maintenance and will provide years of trouble-free service.
Old 04-17-2008, 01:01 PM
JLeuck64's Avatar
JLeuck64 JLeuck64 is offline
Boat: 98 Prostar 190 Stars & Stripes, LT1
Yup, I put one of those on a boat I owned many years ago. It worked great to seal the drive shaft. That boat would still let a little water in through the rudder port however. I wonder if this is your source as well?
Need LT-1 parts?
89058397 (pump outlet side)
Old 04-17-2008, 01:10 PM
coz's Avatar
coz coz is offline
Like I said it's not alot but none is definetly better. So they do a good seal job on the shaft? that's good to hear.
Old 04-17-2008, 01:45 PM
EJ OJPROP's Avatar
EJ OJPROP EJ OJPROP is offline
Have you looked at the XPC SHAFT SEAL Ski Dim part #21705? Less expensive, easier install, no graphite and is standard equipement on many tow boats?
Old 04-17-2008, 01:53 PM
Sodar's Avatar
Sodar Sodar is offline
Boat: '07 ProStar 197 w/ MCX
I agree on the XPC. It is especially nice, because it requires less room on the shaft to install, than the PSS.
-Cameron
2007 ProStar 197
1996 ProStar 190
Old 04-17-2008, 03:26 PM
JLeuck64's Avatar
Yup, I agree. I put the XPC on my present ride just last summer. It was way easier to install than what I remember from installing the PSS design. I like how the color matches my engine too.
Need LT-1 parts?
Old 04-17-2008, 04:07 PM
gigem75 gigem75 is offline
Boat: 83 351
the goretex seal from skidim is pretty darn dry
Old 04-17-2008, 06:03 PM
coz's Avatar
coz coz is offline
This is what I get with that # at skidim, is this it? This says dual graphite
Dual graphite lip seals can be run without the water supply kit. Minimun free length of shaft needed for installation is 7".
Old 04-17-2008, 06:45 PM
chico chico is offline
Boat: 94 205 prostar
I just installed the pss system,works great,I had the goretex packing in there for two years and it made it`s mark on the shaft.
Old 04-17-2008, 06:48 PM
Laurel_Lake_Skier's Avatar
Laurel_Lake_Skier Laurel_Lake_Skier is offline
Boat: 1996 FlightCraft
Coz
Have you tried to adjust your packing? If it still leaks, replacing and then adjusting the packing should do the trick. You might also try greasing the fitting for the rudder, that will help keep some of the water entry back there. Neither job is tough and your bilge should stay dry after you do the work.
Nothing wrong with the shaft seals but the above methods are far less costly and should be effective. I would say I drain a couple of ounces of water when I put the boat back up on the lift after skiing for an hour or so.....and that works for me.
1996 FlightCraft Barefooter—Merc 200 EFI
1991 ProStar 190—Acme 475, GT40-P heads, Edelbrock Performer intake, Mallory YLM Ignition
(SOLD!)
The world is full of youth—what we need is a fountain of smart!
