Old 04-16-2008, 10:21 PM
trunderw trunderw is offline
Boat: 2008 X-14 MCX w/Powerslot
87 fuel filter replacement
So I bought a new fuel filter from skidim a while back and I plan on putting that in soon. So, how the heck do I do that? The thing looks like an oil filter without the metal wrapper so it's just a papery looking tube. Is there pressure on the fuel filter? Can I just open it up and place this in? And how do I open it up? Help appreciated! Thanks
boats rock, but don't rock the boat
Old 04-16-2008, 10:38 PM
stuartmcnair's Avatar
stuartmcnair stuartmcnair is offline
Boat: 1989 Prostar 190 351 Indmar
Send a message via MSN to stuartmcnair
you have a fuel filter in the housing where the fuel line goes to the carb...if you look at it you will see how to remove it. Make sure to clean that bowl out well before you put the new one in. There is also a fuel / water seperator on the other side mounted to the floor that you take the nut off from the top and drop it down.
This board be a changin...
Old 04-16-2008, 10:42 PM
So do I need to buy anything for the fuel/water separator? I've seen it mounted just beside one of the engine mounts (driver's side).
Old 04-16-2008, 10:45 PM
87 TriStar 190 87 TriStar 190 is offline
I have an 87 I bought new and have only changed the filter twice. 946 hours on it. Plan to do it again this spring. I'm going by memory here, so someone may have better advice than I have. Put a drip tray under the filter before you start so you will catch any fuel that drips out. Look under the filter bowl with a mirror to make sure, but I think there's a square nut attached to the bottom of the bowl. Put a wrench on it and turn it off. Just clean it out and replace the filter element. Clean the mating surfaces and install the gasket, which comes with the filter. Turn it back on and snug it up. Don't over tighten it. Remember to remove the tray with spilled fuel. I was worried about priming to fill it with fuel again, but just crank the engine and it will fill and start quickly. At least mine did last time. Good luck and let me know if I'm close to being accurate.
Old 04-16-2008, 10:49 PM
Mine has an orange filter bowl and it's on the passenger side. If there's another separator, I've missed it all these years. Any pictures?
Old 04-17-2008, 08:56 AM
My boat is at the marina where I store it. I'll bring the camera with me this weekend when we go. I'm not sure what the other thing is, I'm not all that savvy with these engines (or any engines for that matter). The fuel filter that I am sure about definitely is on the passenger side towards the front of the motor. That's what my filter replaces. But there is another object of slightly larger size that resembles the fuel filter housing on the driver's side near the side motor mount below the deck level.... Thanks for the input ya'll
Old 04-17-2008, 09:16 AM
TMCNo1 TMCNo1 is offline
Boat: Gone
Attachment 33778
The gold housing in the lower LH corner along the stringer is the water seperator filter and under the black cap is a big nut that you turn to drop the canister that contains the filter element. Hold the cansiter till it drops loose and don't spill it. Place a pan or towels to catch any dripping gas as mentioned above. Replace the filter/gaskets and tighten back up good and snug and wipe everything up. You should also have a small filter element under the fuel pump you need to replace too. http://www.skidim.com/ can hook you up with the parts and/or probably your local dealer, fuel seperator, http://www.skidim.com/prodinfo.asp?number=R080008 and fuel pump filter, http://www.skidim.com/prodinfo.asp?number=3943, just call to be sure! Run engine and check for leaks.
Charter Member Number 1
Quote: 2RLAKE,
Old 04-17-2008, 09:40 AM
mayo93prostar mayo93prostar is offline
Boat: 1993 Prostar 190 Blue Stars and Stripes, Powerslot
Harold, you are too cool. I love the caribeaner holding the oil drain line up on the alternator bracket. another one of harold's innovative ideas.
1993 Blue Stars and Stripes Prostar Powerslot 351HO
Mastercraft: Face It - If you are not a good skier behind this boat, you are not a good skier.
Old 04-17-2008, 11:32 AM
Boat: Gone
That way it is above the oil level in the pan and for whatever reason it should never leak into the bilge. The newer boats had/have a simular feature to clip the line up on the engine, so,............................................I made my own!
Old 04-17-2008, 10:20 PM
TMCNo1: That's the other thingy I was talking about. How often should I replace the water separator?
