Old 04-14-2008, 12:42 PM
nmcjr's Avatar
nmcjr nmcjr is offline
Boat: 2002 X-Star
Oil Bath Hub Manufacturer Specifications
Having seen several posts regarding recommended oil and fill guidelines, I found this document which is from one of the manufacturers of hubs, UFP.
http://www.ufpnet.com/PDF/Trailer%20...aintenance.pdf
UFP specifies 50W engine oil and recommends filling completely and not leaving any air at the top since air expands and contracts more than oil. Anyway, just wanted to pass it on.
Edit: This applies to UFP hubs only. Mine is a '02 and the axle has UFP stamped on the torsion arm. If you read on, it appears UFP was only used for a short time, and MC switched to Reliable.
Old 04-14-2008, 01:09 PM
TMCNo1 TMCNo1 is offline
Boat: Gone
According to Mastercraft Parts/CS, UFP only supplied a oil bath wheel bearing system to MC for approx. 1 year and UFP may have recommend 50wt oil, but since then the supplier to MC has been Reliable and you need to follow their recommendations per your owners manual, if you have a Reliable system.
Charter Member Number 1
Quote: 2RLAKE,
Old 04-14-2008, 02:10 PM
nmcjr's Avatar
Boat: 2002 X-Star
I should have specified, mine is an '02, so the picture at least looks like mine. I cannot find a specific '02 manual, but they look exactly like the hubs depicted in the link below, which look just like the UFP hubs pictured in the UFP manual. Do the Reliable hubs look the same? I can't find a website for Reliable to see a picture.
http://www.mastercraft.com/manuals/Trailer_Manual.pdf
And here I thought I was being helpful....
Old 04-14-2008, 02:43 PM
ncsone's Avatar
ncsone ncsone is offline
Boat: 2005 197TT #28 of 100
IIRC, the Reliable hubs have an oval with the word 'reliable' molded into the clear observation cap on the hub.
Old 04-14-2008, 02:45 PM
nmcjr's Avatar
Boat: 2002 X-Star
OK, upon pulling mine apart, I see that my axle is a UFP. In re-reading p-hat's post it looks like his are in fact different. I am ASSUMING that his are the Reliable hubs--I know at least that they are not UFP. So, I am guessing this is why there are several different recommendations floating around about which oil to use. It appears the UFP specifies 50W and Reliable specifies 80-90W. Now, the $1000 question, is one better than the other? I suppose I will follow the recommendation of my hubs and go with the 50W.
Old 04-14-2008, 10:01 PM
emnesto emnesto is offline
Boat: 2006 X45 LQ9
Once the 50W vs 80-90W question os settled, how about the fill recommendation. UFP clearly said filled means no air. How about a recommendation for Reliable. I checked the MC Trailer Manual, but it's not specific. Mine is an '06, and the hubs have always had about the top 1/4 of air.
Old 04-15-2008, 12:09 AM
vogelm1's Avatar
vogelm1 vogelm1 is offline
Boat: 2005 MasterCraft ProStar 197, MCX
FWIW - In the reliable hubs on mine, I've run both the 50W motor oil and 80-90W gear oil with no difference. Filled up the hub about 3/4 full, but my axle is not pressurized with the spring set up like the one you posted. I can understand why they'd maybe want you to fill that one up completely to avoid water intrusion.
2005 ProStar 197 w/1:1 MCX; Acme #843; 2007 MC ZeroFlex Tower
Old 04-19-2008, 03:38 PM
nmcjr's Avatar
Boat: 2002 X-Star
The logic makes sense to me-a gas (air) will expand much more when heated than a liquid causing a pressure buildup in the hubs, potentially forcing out air or liquid, causing a vaccuum when it cools--i.e. when the hubs hit the water. But, that is just theorizing, would be nice to know what Reliable explicitly recommends.
