Old 04-13-2008, 05:58 PM
Rick_Seebeck Rick_Seebeck is offline
Boat: Malibu Response LXI
Oil change how to?
My "new" boat has a 440 engine in it. There is no way I can get to the oil pan drain plug without pulling the motor. The dip stick hole does not have a threaded hose fitting on it so my oil sucker will not work. Before I tip the boat over to get the oil out I thought I would ask the forum for their ultimate wisdom. How do you get the oil out of this thing?
Old 04-13-2008, 06:10 PM
TMCNo1 TMCNo1 is offline
Boat: Gone
Get a pump with or use a long stiff plastic tube on the end of your existing pump hose that goes down the dipstick tube into the oil pan to the bottom of the pan to suck out the oil. I'll bet the "Helpful Hardware Man" @ Ace Hardware can help you come up with something to make the plastic tube fit your pumps hose!
BTW, I've never seen a dipstick tube with a threaded fitting on it, it's usually just the bare end of the tube and in most cases the dipstick tube usually just goes a couple inches into the block or thru the pan. You've lost me with that one.
I believe we need some pictures to understand!
Charter Member Number 1
Quote: 2RLAKE,
Old 04-13-2008, 06:30 PM
I usually just flip my boat over??
___________________________________________
Myself I'll live on the edge and surf without a helmet.
Old 04-13-2008, 06:32 PM
What is a 440?? Mine has a tube attached to the oil pan, that you can pull through the plug hole to drain the oil. Downside is it takes 19 days to drain out that hose.
Old 04-13-2008, 06:37 PM
Engine Nut's Avatar
Engine Nut Engine Nut is offline
There should be an oil drain hose connected to the bottom of the oil pan at the drain fitting that is designed to be pushed through the hull drain so you can drain the oil into a pan outside the boat. All Indmar engines are built that way. Be sure to warm up the oil by running the engine up to temp and be prepared to let it drain for a long time ... perhaps even overnight. Some people connect a pump to that hose and pump the oil out.
Many stern drives are built with hose fittings on the dipstick tube and the tube goes almost to the bottom of the oil pan so you can suck the oil out with a pump. We do not use that method as we prefer to drain from the bottom of the pan to get more of the old oil out.
Engine Nut
Indmar Marine Engines
Power to the Sport
Old 04-13-2008, 06:45 PM
Slinkyredfoot's Avatar
Slinkyredfoot Slinkyredfoot is offline
Boat: 1979 Mastercraft, 1998 ProStar 205
This coming from someone who applies "Nair" wherever.....doh
Extract the oil throught the dip stick cylinder with a pump designed to do this.
If your boat does not have the oil change hose from the bottom of the pan to the transom of the boat, it might be a good thing to install one...with the crankcase empty of course.....
If for some reason you start to believe you are a person with influence, just try ordering somebody else's dog around.
Old 04-13-2008, 07:48 PM
VTJC VTJC is offline
Boat: None
440 is a Chrysler big block 440. Didn’t know Indmar worked with Chrysler, probably a PCM in an 80’s MC. Once you get your plug out, replace it with one of these http://www.skidim.com/departments.asp?dept=1054
08 Correct Craft Ski Nautique 196 330 HP 350 MPI EFI
Previous Boats:
99 MasterCraft SportStar CB 310 HP 350 TBI EFI
98 Moomba Boomerang 310 HP 350 Carb
88 MC PowerSlot 240 HP 351 Carb Black on White
Old 04-13-2008, 08:53 PM
More info
The boat is a 1983 Pro Star "stars and stripes" The engine is a Chrysler marine engine it has Chrysler emblems on the exhaust manifolds so I do not think it is a PCM or Indmar conversion. The oil pan sits within 1/2 inch of the bottom of the bilge so getting the plug out would really require lifting the engine.
Where do you purchase one of the tools to suck the oil out of the dip stick hole?
Old 04-13-2008, 09:04 PM
Boat: Gone
Here is an example, http://www.skidim.com/prodinfo.asp?number=6001316, there is a rubber adapter that may work with your other pump so you can use the black tube into the dipstick tube,
Attachment 33637
Old 04-13-2008, 09:32 PM
Hrkdrivr's Avatar
Hrkdrivr Hrkdrivr is offline
Boat: MasterCraft X-45, 2006, L18, slate gray/white
Here's what I used. It more than pays for itself the first time you use it compared to paying someone to do it. It comes w/a plastic tube you can snake down the dipstick tube. Like already mentioned, make sure you warm up the oil first. It's kinda slow, but you can also use it to drain the oil from your tranny. It has a 3.5 gallon capacity and I was able to get the ~2.5 gals out of my engine and the ~1 gal out of my tranny w/room to spare.
I got it thru Amazon and it looks like the price has dropped...
http://www.amazon.com/Jabsco-17860-0...8136139&sr=8-2
2006 X-45, L18, slate gray/white
