tranny fluid in v-drive
i purchased a 97 200vrs. previous owner just had shop change all fluids. engine,tranny,v-drive. the tranny and v-drive both have tranny fluid. should a guy suck tranny fluid out of v-drive and put motor oil in. or is tranny fluid okay?
Unfortunately, the owners manual for your boat (at http://www.mastercraft.com/manuals/1...S200-MS205.pdf) doesn't specify what the v-drive should contain. ATF in the transmission, sure.
Hopefully, one of the other experts will help you out. My boat isn't close enough. /frank
1998 Maristar 200VRS |
Uh Oh
Oh crud...I thought the v-drive WAS the tranny...are they two different things?!?
2006 X-45, L18, slate gray/white I am leaving it as I found it. Take over. It's yours. - Ellis Wyatt, Atlas Shrugged |
'04 MariStar 230VRS/MCX |
I have a 94 225 vrs with a Walters V drive. The trans is a Velvet drive. On Walter's website you can down load the manual. If not I scan my copy and e-mail it to you. Their manual states "Unscrew the #12 Breather cap and fill the V-drive with SAE #30 heavy duty non-getergent motor oil through the #12a breather elbow". The model will determine the amount needed.
#7
if v-drive is not separate from tranny than why the two dipsticks
#8
HrkDrivr and I only have one dipstick in our ZF Hurth V-drive transmissions.
#9
vdrive
thanks you guys but both mastercraft vdrives i have have a dipstick in tranny and another black looking knob that is a dipstick in vdrive unit under rear seat
#10
