351 head bolt torque specs
Anyone know the torque specs for a Ford 351w HO Indmar engine. I had to undo the 2 bolts that hold the throttle cable bracket on.
1992 Prostar 190, Indmar 351 HO, 1:1 Velvet Drive |
I am a huge fan of tightening per torque specs! I don't know the answer, but I'm sure it will be along shortly! Great question!
According to my Ford small block rebuilding book it should be 55 -65 ft lbs
1997 Prostar 190, TBI 350, 1:1, OJ XMP 13 x 11.5, Stargazer, Hot Shower, Heated Drivers Seat, Reuben/Mountain Rock/Nite Navy |
Looking at my Indmar manual, the 55-65 is for the 302. 351 says to tighten in steps. First to 85 ft/lbs then a final to 95 ft/lbs. The 351 uses larger 1/2" bolts. Also, there is a tightening sequence, starting in the center and moving out.....not sure what effect pulling out one or two bolts will have on needing to follow the sequence.
1991 ProStar 190—Acme 475, GT40-P heads, Edelbrock Performer intake, Mallory YLM Ignition The world is full of youth—what we need is a fountain of smart! |
I am thinking those 351's used INTAKE manifold bolts to hold the throttle cable bracket in place. If so, the specs for them would be a lot less than a cylinder head bolt...
http://www.mastercraft.com/photopost...er=2572&sort=1 Need LT-1 parts? OIL FILTER: Factory installed is a Penzoil P23, Afta market brands, AC Delco PF-454 and a Fram PH-13 or PH-30 will work. SPARK PLUGS: AC Delco MR43LTS (gapped to .040") FUEL FILTERS: AC Delco 25171391 (pump inlet side) 89058397 (pump outlet side) IGNITION WIRES: Call Inboard Online @ (877) 327-7175 and order part numbers 556010A (odd bank) and 556010B (even bank) |
#7
Check this info: http://www.marineparts.com/mpf/mpf520.aspx
1992 Prostar 190, Indmar 351 HO, 1:1 Velvet Drive Last edited by climbinggod; 03-13-2008 at 10:46 PM. |
#8
make sure you have head bolts not intake manifold bolts. did you take off a valve cover? or go below it?
head bolts should be tightened in sequence to torqued to specs. USING NEW BOLTS. YOU CAN'T REUSE HEAD BOLTS. My guess is you have intake bolts, not cylinder head bolts. post a pic, we can help. |
#9
PCM 351w, 350hp |
#10
Here is a picture of the rear of the engine. You can see the black throttle cable bracket mounted on the top of the engine. Any help to you? Manifold or head bolt??
