Old 02-05-2008, 10:30 AM
bbeach's Avatar
bbeach bbeach is offline
Boat: 1990, Prostar 190, 351 Indmar
1990 Prostar 351 Pulley squeak
All last season I fought what I thought was a squeaky belt on the front of my 351 - but after changing the belt twice and some belt dressing I believe the problem is one of the pulleys on the front of the block. Anyone else ever have this problem and which pulley should I consider changing first?
Keep in mind it sounds like a belt but its not. It squeaks on startup and for the first few mins the boat is running? It seems once it gets warmed up it stops.
any suggestions other than replacing them all? Are there bearings in these pulleys that can go bad?
thanks
KStateSkier
"Le ore del mattino hanno l'oro in bocca"
The morning hours are the most precious of the day!
Old 02-05-2008, 10:31 AM
cbryan70's Avatar
cbryan70 cbryan70 is offline
Boat: 1978 mastercraft
Send a message via AIM to cbryan70
is the belt tension correct?
Old 02-05-2008, 10:41 AM
flipper's Avatar
flipper flipper is offline
water pump or alternator? Sounds like it could be a bearing or something in one of those.
'91 prostar 190
Old 02-05-2008, 10:47 AM
bbeach's Avatar
yes I believe the belt tension is correct...
KStateSkier
Old 02-05-2008, 10:48 AM
bbeach's Avatar
The alternator is original so it may be time for a new one anyhow...
KStateSkier
Old 02-05-2008, 10:53 AM
Prostar Rich's Avatar
Prostar Rich Prostar Rich is offline
Boat: Mastercraft Prostar 190 1990 351 Ford
I second taking a closer look at your alternator. You may have bearing that going south on you.
Prostar Rich
Old 02-05-2008, 11:14 AM
bbeach's Avatar
I think the alternator would be a good start. I'll pull it this weekend and have it tested. I would imagine when I take it to Orielly's and have it tested it will squeak and possibly might be running short.
thanks all!
KStateSkier
Old 02-05-2008, 11:48 AM
stuartmcnair's Avatar
stuartmcnair stuartmcnair is offline
Boat: 1989 Prostar 190 351 Indmar
Send a message via MSN to stuartmcnair
replace them all...as long as you are working on it you might as well
This board be a changin...
Old 02-05-2008, 12:18 PM
TMCNo1 TMCNo1 is offline
Boat: Gone
A couple times in the past, our raw water pump impeller was worn, causing it to squeek and changing the impeller stopped the noise. It may be worth a try.
Charter Member Number 1
Quote: 2RLAKE,
Old 02-05-2008, 12:31 PM
bbeach's Avatar
I change my impeller every season anyway. IMO there is no reason not to when its a $28 part and it can just as easily fail anytime.
KStateSkier
