Old 01-21-2008, 04:04 PM
SoCal205's Avatar
SoCal205 SoCal205 is offline
Boat: mastercraft, prostar 205, 1993
new prop install
I recently bought a new prop on the install directions it says to have 60% contact. My mastercraft manual says 70% contact, it also says to use a compound called persain blue and a grinding compound. So my question is where can I find these compounds? Or does anyone have any other suggestions.
Old 01-21-2008, 04:09 PM
CRAIGTHEMAN's Avatar
CRAIGTHEMAN CRAIGTHEMAN is offline
Boat: 2000 mastercraft x-star 330hp
for years iv been switching my prop on my boat and all i do is get the old one off,put the new one on and get the nut somewhat tight than throw the cotter pin in...hasn't failed me yet
Old 01-21-2008, 04:30 PM
TMCNo1 TMCNo1 is offline
Boat: Gone
This thread may give you some information about Prussian Blue. Prussian Blue also known as Engineers Blue and Valve/Grinding Compound can be found at most auto parts stores and where machinists/metalworkers get their supplies. Here is a more in depth explanation of it's use, http://en.wikipedia.org/wiki/Prussian_blue and here http://en.wikipedia.org/wiki/Engineer%27s_blue .
Charter Member Number 1
Quote: 2RLAKE,
Old 01-21-2008, 04:54 PM
Sodar's Avatar
Sodar Sodar is online now
Boat: '07 ProStar 197 w/ MCX
SoCal... all they are trying to do with the substance recommended is keep the dissimilar metals away from one another (stainless & nibral/bronze). A few years ago, when I worked for a local High-Performance boat shop, the head mechanic recommended this. It is a teflon based waterproof grease. The stuff is TOUGH and not cheap, but a little goes a very long way. Anyways, after seeing the conditions that this grease held up in, I am sure it will provide the same benefit as those you listed, but be a little easier to find!
-Cameron
2007 ProStar 197
1996 ProStar 190
Old 01-21-2008, 05:10 PM
Boat: Gone
I always apply some Lubrimatic Marine Corrosion Control and Trailer Wheel Bearing Grease to the shaft, key slot, key and inside the prop hub before I install the prop. You would be surprised how much of it is still there when the prop is removed, even though it took a prop puller to get the prop off.
Old 01-21-2008, 06:05 PM
JLeuck64's Avatar
JLeuck64 JLeuck64 is offline
Boat: 98 Prostar 190 Stars & Stripes, LT1
Here is a simple way to check the contact between your prop and shaft.
WITHOUT the new key installed in the keyway, slide the prop onto the shaft until it stops. Now mark around the shaft, with a Sharpie, to indicate how far up taper the prop fits.
Install you new key into the keyway and install the prop and nut as per directions. Now, in it's final resting position the prop should at least come back to your indicator mark, or it may just start to cover the mark. This is good, you don't have to worry about the key shifting causing an interference between the fit. Which is what we are most concerned about. The 60% contact sounds more like a racing/High perfromance concern to me. I would bet if you checked it with Prusian blue it would be fine anyway...
Need LT-1 parts?
89058397 (pump outlet side)
Old 01-21-2008, 07:34 PM
Boat: Gone
It has to do more with the mating of the shaft and prop hub surfaces, than how far the prop goes up on the shaft. I would think, that since it is in the owners manual there is a reason for it to be there, just like the instructions for changing the engine/transmission oil and related filters, greasing the steering fittings, shaft alignment, among other maintenance items to be addressed during ownership, but.....................
Maybe Eric from OJ will give us some advise on this subject.
Old 01-21-2008, 07:43 PM
coz's Avatar
coz coz is offline
Boat: 1998 ProStar 205
I just asked this same question 2 days ago and these great folks at TT squared me away, looks like you got the same treatment Thanks again on this post.
Old 01-21-2008, 07:45 PM
Sodar's Avatar
Originally Posted by TMCNo1
...I would think, that since it is in the owners manual there is a reason for it to be there....
I tend to take Mike's stance. Seems like alot of the stuff in the manuals has more to do with CYA, than actual necessity.
Originally Posted by MYMC
Throw the manual away...no reason to hold on to a book of suggestions...wonder why they waste the paper on printing those things anyway?
http://tmcowners.com/teamtalk/showpo...75&postcount=6
-Cameron
2007 ProStar 197
1996 ProStar 190
Old 01-21-2008, 07:48 PM
coz's Avatar
coz coz is offline
This is a mecury product and the stuff works great on all kinds of applications.
