Old 01-19-2008, 10:50 PM
coz's Avatar
coz coz is offline
Boat: 1998 ProStar 205
Prop Questions.
So, all my prop experience is with o/d's and not sure the differences in pitch/diameter with the direct drive props, and what I can expect from this OJ 13 prop I picked up today? My boat has the original 4 blade stock prop now. Any advice would be greatly appreciated on this and the install, thanks.
New prop.
Existing prop.
Thanks again
Old 01-19-2008, 11:32 PM
JLeuck64's Avatar
JLeuck64 JLeuck64 is offline
Boat: 98 Prostar 190 Stars & Stripes, LT1
Your new prop looks like it is the same pitch and diameter as the old. How come you want to change it?
Need LT-1 parts?
89058397 (pump outlet side)
Old 01-20-2008, 08:19 AM
coz's Avatar
coz coz is offline
I needed a just in case prop and this set up only cost $60 with prop, wrench and new nut & key and there was a brand new impeller in the box too. So I couldn't pass it up even if it didn't fit I would have bought it for that price (the guy was desperate) So this prop does appear to be a little bigger with a different pitch/cup and it says 13 on the oj. It's definetly different the blades on the stock one seem a little smaller.
Old 01-20-2008, 12:13 PM
wakolman wakolman is offline
Boat: 2005 197TT- SOLD
Contact this TT member- EJ OJPROP
Eric will ask you some questions and you will know if you have the right stuff.
2005 197 TT-SOLD
2006 4Runner
2006 2500HD Silverado Duramax -SOLD
2007 Lexus ES350
Old 01-20-2008, 02:50 PM
TMCNo1 TMCNo1 is offline
Boat: Gone
So, the guy was desperate, eh? Did he try to sell you his crack pipe too, if he let you have all that for $60?
Charter Member Number 1
Quote: 2RLAKE,
Old 01-20-2008, 06:08 PM
coz's Avatar
coz coz is offline
That was my first thought too but it came from an estate sale and it's obvious they mis-priced this item So I'm checking my manual and it says apply "prussian blue" and if less than 60% contact use lapping compound then remove it with solvent? Not sure I'm getting this what's the blue stuff and what's the lapping compound do if I need to put it on then remove it?
You mean I can't just grease the shaft and switch out props? and go!
Thanks
Old 01-20-2008, 07:02 PM
Boat: Gone
Applying Prussian Blue" (similar to a dye) to the shaft and it dyes the shaft blue, then the prop is spun on the propshaft w/o the key in place and the blue tint is wore away showing the contact of the prop to the shaft. You sand down the shaft in the remaining blue tinted area with emory cloth or use valve grinding compound to match and mate the 2 surfaces of the prop and shaft completely, clean it all up with solvent and install the prop for use. Most people never go to the trouble and now with the new splined props and shafts there is no need to do it. BTW, there is a section in most all owners manuals explaining the process in the prop removal/replacement section as you said.
Old 01-20-2008, 07:33 PM
coz's Avatar
coz coz is offline
Thanks TMCNo1, I saw that in the manual but it didn't explain it like you and I appreciate that, great info from this site thanks again.
