Old 12-29-2007, 12:11 AM
climbinggod's Avatar
climbinggod climbinggod is offline
Boat: 1993 prostar 190
Boat don't want to go wakeboarding speed
I have a '92 prostar 190 and I am always feathering the throttle to keep the boat around the right speed for wakeboarding. There seems to be no problem with skiing. Is this normal or is there something I can do. I know perfectpass is an option. BTW...It has the original 4010 Holley Carb!!!
Old 12-29-2007, 12:25 AM
03 35th Anniversary's Avatar
03 35th Anniversary 03 35th Anniversary is offline
Boat: Searching
Prop
Prop
Prop
you got a 3 blade or 4??????
Old 12-29-2007, 12:46 AM
rem_pss308's Avatar
rem_pss308 rem_pss308 is offline
Boat: 1999 X-Star 330 HP
Send a message via Yahoo to rem_pss308
I have a 1993 205 and I have the same problem.
The perfect speed for wake size is right when it is just about to plain out. if it plains, then the wake gets smaller.
it is very hard to stay in the sweet spot.
our hulls are not designed to throw a wake.
"Let me not pray to be sheltered from dangers, but to be fearless when facing them."
1999 X-star, 330 LTR, Zero FLex tower.
Old 12-29-2007, 07:38 AM
1boarder 1boarder is offline
Boat: 2008 X2, MCX
You can add weight to the front or back to change the speed that it planes out at. I would start with weight in the back to keep it from planing out at your boarding speed and giving you a bigger wake.
Old 12-29-2007, 12:34 PM
Originally Posted by 03 35th Anniversary
Prop
Prop
Prop
I have a 3 blade prop
Old 12-29-2007, 01:00 PM
lanier92prostar's Avatar
lanier92prostar lanier92prostar is offline
Boat: 1992 Prostar 190
I have a 92 also. I put a fat sac in the back and 50 to 100 pounds in the front under the bow. It seems to keep the speed fine with the ballast in the back. The lip of the wake gets better with a little more weight in the front. Also you can move the weight in the front to offset weights of people in the boat to get a consistant wake on both sides. I hope this helps.
Old 12-29-2007, 01:26 PM
Thanx, Do you take the back seat out to use the fat sac in the back? What sort of size fatsac are we looking at?? How many lbs in the stern ballast or people. I was thinking of getting a fatsac but not sure which one would be best.
Old 12-29-2007, 04:24 PM
Boat: Searching
4 blade will be your bestfriend. You will lose alittle top-end speed, but you will beable to hold a constant low speed easier.
I got a friend that had a 92 205, and that was what OJ props told him.
Old 12-29-2007, 05:19 PM
BrianM's Avatar
BrianM BrianM is offline
Boat: 1988 Prostar 190
That is just your '92 telling you it is a SKI boat. 36mph is all you need.
Old 12-29-2007, 05:20 PM
André's Avatar
André André is offline
Boat: Prostar 190 1994
I knew it was coming!
Keep skiing!!!
