Old 03-21-2005, 08:04 AM
skilew skilew is offline
Stuck Thermostat Cover
Engine acts as though the thermostat is stuck open. Will not get over 120 degrees F so I decided to replace it.
Tried to replace thermostat this weekend, removed the two cover bolts but the cover acts as though it were welded on. It will not budge. I did not want to be too aggressive and crack the cover. Any suggestions?
Old 03-21-2005, 08:12 AM
jsonova99's Avatar
jsonova99 jsonova99 is offline
Boat: 1991 Mastercraft Prostar 190
Could you try heating it up a little with a heat gun or something? That little bit of expansion might be enough to knock it loose. I can't picture what mine looks like right now so I don't know if this is feasible or not. I'm sure somebody else will chime in with some ideas.
1991 Prostar 190 - Ambush 4 blade prop
Old 03-21-2005, 08:18 AM
PeteS's Avatar
PeteS PeteS is offline
Boat: 1988 Prostar 190 - 351 Indmar (1:1) / 365 Hours
I had a similiar problem in my '88 with the thermostat, and the cover was seized a bit as well. Here's what I'd do. Squirt some PB Blaster down the bolt holes, and around the seams of the cover. Tap it gently with a hammer, or rubber mallet. Repeat, then pull it off.
Once you access the t-stat, if you notice it OPEN, that explains your temperature problems -- mine was corroded wide open. Let us know how it goes.
1988 Prostar 190 - 351 Indmar (1:1) / PerfectPass Digital Pro 6.5n, 13 x 12 Acme 3-Blade
Old 03-21-2005, 08:30 AM
Footin's Avatar
Footin Footin is online now
Boat: 2007 Maristar 200VRS X2
You said you removed the "two" cover bolts, I believe your are removing the wrong cover. Doesn't the t-stat houseing have 3 bolts holding it together? You are probably removing the neck into the manifold and the stat is in the other housing.
Old 03-21-2005, 10:12 AM
dsoby's Avatar
dsoby dsoby is offline
Boat: 2002 X7, LTR
Lew,
I can't tell what kind of boat you have but my engine (LTR) has a 120 deg. thermostat as standard equipment.
Old 03-21-2005, 11:17 AM
Boat: 95 PS 190 EFI
I have to agree - on my '95 PS190, it's 3 bolts holding the cover on the T-stat. What boat do you have?
If one day you're asked:
Will you say:
It's time to SKI.
Old 03-21-2005, 11:54 AM
Lance Lance is offline
Boat: 1987 Prostar 190 PowerSlot, 2004 22' Bennington Pontoon 90 HP Mercury 4-stroke
My 87 prostar also has three. The cover is the triangular shaped housing at the very top front of these older Ford engines.
Old 03-21-2005, 12:54 PM
I have a 1993 Ford 351 with the GT-40 heads.
It sounds like I may have missed a bolt only saw two but will recheck today. I am removing the cover that has the three hoses going to it. Is this the right cover for the thermostat?
Old 03-21-2005, 12:58 PM
G-man's Avatar
G-man G-man is offline
I don't think you have the correct cover. Should be top left front side triangle in shape.
06 AWSA Approved Towboat
Old 03-21-2005, 01:24 PM
Should only have two hoses going to the cover... the two hoses go to the exhause manifold (right & left).
