Old 03-20-2005, 10:30 PM
6ballsisall's Avatar
Boat: None this week!
Prop Removal
I bought the Acme prop removal kit (weekender kit) and was trying to use the Harmonic puller to get the OJ legend off. No such luck, it is really on there!! Any recommendations to get that prop off there?
Old 03-20-2005, 11:03 PM
whitedog's Avatar
whitedog whitedog is offline
Boat: maibu sportster
Use the prop puller, tighten the puller then heat the prop where it goes on the shaft with a torch. If you do not have a big tourch go buy a small one. Get MAP GAS, Yellow bottle, it is much hotter than propane. Get it good and hot then rap it with a hammer. Usually does the trick.
Old 03-21-2005, 03:11 PM
rem_pss308's Avatar
rem_pss308 rem_pss308 is offline
Boat: 1999 X-Star 330 HP
Send a message via Yahoo to rem_pss308
I changed mine about two weeks ago.
I didnt have a prop puller.
I used a propane cylinder( used to solder plumbing pipes)
It didnt take long heating it, and then lightly tapping with a hammer.
It jumped right off.
( dont forget the prop is HOT!!!!! )
"Let me not pray to be sheltered from dangers, but to be fearless when facing them."
1999 X-star, 330 LTR, Zero FLex tower.
Old 03-21-2005, 08:38 PM
Wes Wes is offline
Boat: 1993 ProStar 205
Rem,
I have the same boat and replacing the prop as well, did you use a torque wench to tighten the prop? If so what did you torque it to?
Thanks
Old 03-21-2005, 10:24 PM
Cloaked Cloaked is offline
Boat: MasterCraft
Barely snug tight and the cotter pin is all I ever use. Personally, I do not recommend and premeditated torque....
Old 03-22-2005, 10:35 AM
Wes Wes is offline
Thanks Sporty
Old 03-22-2005, 10:52 AM
rem_pss308's Avatar
Mine had a brass nut with the plastic inside. After multiple removals. It is kind of loose. I will be purchaseing a new one. All Brass with notches.
I did not torque too tight. But I did add a cotter pin.
Old 03-26-2005, 09:22 PM
Help!!!
Still can't get the prop off!! Put a propane torch to it and still wont budge, hit it with a hammer and beat the snot out of the harmonic dampener. Nothing!! Help!!
Old 03-26-2005, 10:06 PM
mbeach mbeach is offline
Boat: 1998 sportstar 19
i had same problem getting prop off. purchased a $10 propane portable tourch and heated. beat on rear of prop with a hammer and block of wood. nothing!!! sound familiar? repeated and still nothing. again, same result. finally, decided all those having success with this method cannot be wrong, so heated the squat out of prop being sure to heat not only the end but the entire length of prop shaft also in between blades. hit twice and popped off. so, moral of story is that you really need to get the prop hot to the extent that the ends of the blades are too hot to touch. i was figuring originally should take 5-10 minutes or so, but wound up taking 1 hr+. the key seems to be getting the prop shaft really hot which will take time. was 25F when i did it. like others have suggested, prop will pop off so i used a coat hanger inserted into cotter pin hole on drive shaft and be sure to grab prop with good set of pot holders since that puppy is really hot. good luck!
Old 03-26-2005, 10:08 PM
So should I be heating the shaft to? I was just heating the prop
