Old 12-05-2007, 06:28 PM
wsrobert wsrobert is offline
Boat: .
Dessicant
Has anyone used any kind of drying dessicant to keep moisture out of the engine compartment when the boat is stored for winter. I have a full cover, but I'm concerned about condensation on the engine. I live in south Louisiana and we don't have very cold winters, but the humidity is always high. Just looking for anyone's thoughts.
Old 12-05-2007, 06:29 PM
cbryan70's Avatar
cbryan70 cbryan70 is offline
Boat: 1993 Prostar 205
i use a bucket full of charcoal
Old 12-05-2007, 06:54 PM
Boat: .
You mean like Kingsford or Matchlight??? Does that really work???
Old 12-05-2007, 07:05 PM
cbryan70's Avatar
thats what i use seems to work fine.
Old 12-05-2007, 08:21 PM
bigmac bigmac is offline
Boat: 2004 Maristar 230 VRS
I use a Turbo Dryer thingy. Circulates air that's just warm enough to keep the inside of the boat above the dew point. I leave it plugged in all winter - uses about the same amount of electricity as a 100 watt light bulb (they say).
They have them at Overtons.
'04 MariStar 230VRS/MCX
Old 12-05-2007, 09:13 PM
Bruce Bruce is offline
Boat: 1999 MariStar 230 VRS 5.7 Indmar Vortec
Mac, I have a similar one I got from West Marine does not seem to be doing the job. Of course the humidity here is off the chart at times. I have it in the back on the round black plate over the drain (was not sure about leaving it on the carpet. Of course I could put something under it. Be that as it may it may just not big enough for the boat(230 VRS. which I believe you have)Any thoughts? I had thought about kitty litter(earlier post) but the feeling seem to be that it would not work. The charcoal idea? The boat hangs in the slip under a cover.
"IT IS WHAT IT IS'
Old 12-05-2007, 10:00 PM
If one doesn't do the job, I'd add a second one. Not a big believer in dessicants...the concept isn't as appealing to me as something that plugs into the wall.
Old 12-05-2007, 10:05 PM
Yeh, I have the same boat. The humidity isn't as high here, especially in the winter, but mold is still a problem during storage.
If one of those dryer things doesn't do the job, I'd add a second one. Not a big believer in dessicants...the concept isn't as appealing to me as something that plugs into the wall - removing moisture as opposed to preventing it from condensing.
Old 12-05-2007, 10:23 PM
Leroy
Just a fan and small heater? How hot does it get? I wonder if it would work since the delta from ambient to this device is probably a lot less in the deep south? Pretty smart solution!
"Circulates air that's just warm enough to keep the inside of the boat above the dew point. "
Old 12-05-2007, 11:35 PM
Like Mac said it is about the same as a light bulb. Not real hot you could put your hand on the metal case. I haven't had a problem with heat but I think I will get a second one. Need to figure out if there is any difference in the one I have or the one Mac showed.
"IT IS WHAT IT IS'
