Old 11-23-2007, 05:35 PM
ejkjell's Avatar
ejkjell ejkjell is offline
Boat: Prostar 197
Engine Flush Device
I'm looking for a device to hook up a garden hose to the engine to flush it this spring before I put it in the water. My dealer uses a little connector that connects directly to the engine on one of the coolant hoses. I have also seen the plunger devices that attach to the bottom of the boat. Any thoughts on those? I have a '04 Prostar 197.
Old 11-23-2007, 05:54 PM
Footin's Avatar
Footin Footin is offline
Boat: 2007 Maristar 200VRS X2
The one that looks like a plunger is a "Fake-a-Lake", I use one and think they work well.
OH-IO!
Old 11-23-2007, 06:03 PM
JohnE's Avatar
JohnE JohnE is offline
Boat: 40th Anniversary X14
I use rubber hose and clamp it to the raw water intake and the garden hose based on the advice of MYMC. Worked great.
40th Anniversaary X14
Prior boats - 2009 X14, 2008 X14, 2005 197, 1997 Prostar 190, 1988 Tristar 190, 1989 Prostar.
Old 11-23-2007, 07:08 PM
Chief's Avatar
Chief Chief is offline
Boat: 2006 Maristar 200VRS
http://www.foreandaftmarine.com/7-0418.htm
External flush connection for about twenty bucks. Use in conjunction with perko flush pro and you will never have to lift your engine cover to flush again.
2006 Maristar 200VRS MCX
KGB Ballast and all the works! (Once upon a time)
Tow Veh: 2010 Toyota Tundra
Bike: 2009 HD Street Glide
Beer:Ballast Point IPA's
Chief Petty Officer: "Results not excuses"
"You Can't Beat a Tree"
Old 11-23-2007, 08:32 PM
School Skier School Skier is offline
Boat: MasterCraft ProStar 190 1997
I disconnect the raw water hose and put a long clear non crush type hose to the intake. I use a large drum and fill it with water and let the water run even while the engine is running. Never had a problem with it. JimN used that on our boat many moons ago and I use that method when ever I have to start the engine out of the water.
Old 11-23-2007, 11:33 PM
mc79 mc79 is offline
Boat: MasterCraft, 1979, Pleasurecraft 302
Flush Pro 1" or Flush Pro 1.25" installs in-line with the fresh water intake. It works well, $57 at www.skidm.com. You can also use it to suck aintifreeze out of a bucket for winterization. Installation beside/below the engine can be a bit tight. I marked the fresh water line, removed it from the boat before trying to squeeze the line on to the Flush Pro. Another tip, use a brass garden hose "quick connect" coupling to attach the hose.
Old 11-23-2007, 11:47 PM
dmayer84's Avatar
dmayer84 dmayer84 is offline
Boat: Mastercraft X10 2004 5.7L
If the bunks cover the intake like they do on my x10 the fake a lake will not work. What I put together is a ball valve on the intake side to shut off the intake and then connected to it running towards the engine a connection for a garden hose. I just dont trust the plastic on the flush pro, I think someone on here had theirs start leaking on them.
Old 11-24-2007, 11:18 AM
Patrick Hardy's Avatar
Patrick Hardy Patrick Hardy is offline
Boat: 1996 Prostar 190 W/ LT-1 & Powerslot
I have a few questions about this topic. where do you place the water inlet fitting / external flush connector on your boat? How long does the whole system take to install? Have there been many complaints about this system leaking? Thanks for any input.
Old 11-24-2007, 11:44 AM
TRBenj TRBenj is offline
Boat: 1990 Ski Nautique
Or you can skip the flush pro altogether and build your own for $15. All you need is a 1" (or 1.25") plastic Tee, 2 hose clamps, a NPT to GHT fitting, and a garden hose valve. Mine has the quick disconnect built in.
Old 11-24-2007, 12:05 PM
dmayer84's Avatar
My setup is pretty much the same but all metal and below the quick connect I have a ball valve so the water doesnt start going out the intake, or allow air into the system.
