Old 03-08-2005, 01:18 PM
jayderwin1's Avatar
jayderwin1 jayderwin1 is offline
Boat: MasterCraft, ProStar 190, 1986, 351.
slight knocking sound coming from the shaft
has any one ever heard a slight knocking sound coming from some where around the shaft area when the boat is in gear at low RPMs?
Old 03-08-2005, 01:38 PM
Brn85ss Brn85ss is offline
Probably your dampner plate.If it goes away at higher rpm in gear thats probably it.Doing mine this spring should only take an hour or two.
Old 03-08-2005, 01:48 PM
jayderwin1's Avatar
can you explain what a damper plate is and does? mine will knock at the slowest RPM i can go in gear as soon i give it a little more gas the noise will go away.
Old 03-08-2005, 01:57 PM
Someone else might be able to explain this better than I, but here it goes.The dampner plate filters out the harmonic vibrations of your drive train when the springs start to wear or break that is the sound or rattle you here.Should be replaced right away so it does not put extra strain on the trans.Also if you have a slight miss in your engine it will sometimes make your dampner rattle.I'd make sure your engine has a full tune before your sure it's the plate.Chased this in my buddy's malibu,all it needed was a tune.Skidim has them for about 90.00.
Also it could be something else but this is pretty common problem,try to isolate the rattle.
Old 03-08-2005, 02:04 PM
jayderwin1's Avatar
is this plate located in the transmission? my engine also might have a slight miss but very slight if it does.
Old 03-08-2005, 02:28 PM
Professor's Avatar
Professor Professor is offline
Boat: Prostar 190, 1998, LT1, powerslot
Good Info. Our CC has been doing this for several years and runs great even though the motor has a zillion hours
- where every family lives on the lake, every neighbor is a ski club member, and at every dock there is a Mastercraft
The plate is in the bell housing,all it takes is a slight miss.
Old 03-08-2005, 02:29 PM
ski_king's Avatar
ski_king ski_king is offline
What is you idle speed?
Mine had a simular rattle, kicked up the idle about 100 rpm and it went away.
STARS AND STRIPES FOREVER
Old 03-08-2005, 02:34 PM
martini's Avatar
martini martini is offline
Boat: Mastercraft, Prostar, 1984, PCM 351, 1:1
The plate is attached to the flywheel. It is between the transmission and the engine. The cast iron part(BELL HOUSING) that is between the engine and the transmission, is where you'll find the damper plate. Replacement requires lifting the rear of the engine a little to gain access to everything. An engine hoist should be used.
Old 03-08-2005, 03:35 PM
jayderwin1's Avatar
my idle speed is about 600 i goes up and down with how long the motor has been running.
