Old 09-17-2007, 10:14 PM
Ben Ben is offline
Boat: '94 PS205 LT1
Fat Sack Question
Novice wakeboarder looking for advice on fatsack types & brands...
I'm looking for a cheap way to get 400-500lbs in the back of the boat. Wife doesn't want it at all, so needs to be cheap. For one bag, should I be worried about getting the old vs. new style connectors / pumps, etc?
I found a "lauch pad" - 680lbs & pump for $100, but it's the old style connector. Never used. How long would this take to fill? Do the newer ones fill A LOT faster? I may be able to add this to the x-mas list, and want something I'll be happy with.
Any opinions / advice?
Old 09-17-2007, 10:54 PM
Chief's Avatar
Chief Chief is offline
Boat: 2006 Maristar 200VRS
I would look for a 400 lb for the back and a 250 for the front. Too much in the back will make the ramp steep. Good rule of thumb: 60% rear 40% front. Type of boat? You could always go with 300 lbs on each side of motor if it's a direct drive.
2006 Maristar 200VRS MCX
KGB Ballast and all the works! (Once upon a time)
Tow Veh: 2010 Toyota Tundra
Bike: 2009 HD Street Glide
Beer:Ballast Point IPA's
Chief Petty Officer: "Results not excuses"
"You Can't Beat a Tree"
Old 09-17-2007, 10:57 PM
Ben Ben is offline
Boat: '94 PS205 LT1
Thanks, hadn't thought that direction yet. It's a PS205 Direct Drive.
I'm planning to put the few people we usually have in the front. Driver, one in the observer seat, one in the bow, ballast in back. I guess if we only have 3 total, the front may be a bit light...
Old 09-17-2007, 11:03 PM
Chief's Avatar
I had a 99 PS205 and I installed a 600 lb bag in the trunk and a 400lb in the ski locker with a ballst puppy pump and the wake was pretty sick. Good ramp to launch from.
Picture of wake added.
Old 09-18-2007, 09:34 AM
Ben Ben is offline
Boat: '94 PS205 LT1
Pic looks great, ski locker sac will also be on the lookout list.
Any advice on old vs. new fittings and drain / fill times?
Also, for a rear sac, should I worry about newer bags w/o covers, or are they plenty durable. It will be out in the open.
Thanks.
Old 09-18-2007, 09:40 AM
Maristar210's Avatar
Maristar210 Maristar210 is offline
Boat: paddle
Old or new they are all a PIA to fill and plan on getting the floor wet. Something to be saud for pumbing the sacs semi-permanently. It's on my to do list but never seems to get very high....
Old 09-19-2007, 08:08 PM
beatle78 beatle78 is offline
Boat: 2001 Prostar 205V
I would DEF go with the Tsunami pump.
I've bene told they fill significantly faster than any of the 1000GPH pumps.
Here's a thread where he used the Tsunami pumps for an auto ballast system.
http://www.tmcowners.com/teamtalk/sh...t=205v+ballast
5 MINUTES to fill all his sacs......
Also, make sure to open a vent tube when filling the sac to reduce back pressure and to increase fill time.
Old 09-19-2007, 08:17 PM
Chief's Avatar
Thanks.
I had the old waterbed fittings in the old girl with one pump and a Y-gate valve to change when the filling sack was full.
I had the sac with the cover, but with new technology your probably ok without the cover.
Old 09-24-2007, 08:30 PM
Jerseydave's Avatar
TT Hero
Go with Fly-High sacs with quick-connects and a Tsunami pump. The old-style threaded fills are a PITA.
Try here:
www.wakeside.com
www.buywake.com
I was njskier on here.
Old 09-27-2007, 06:27 PM
stuartmcnair's Avatar
stuartmcnair stuartmcnair is offline
Boat: 1989 Prostar 190 351 Indmar
Send a message via MSN to stuartmcnair
get some...
extra friends to ride with you...move them around in the boat and see what makes the best wake...then judge their weight to get a good measure of the size and location of your sacks
