Old 03-04-2005, 11:14 AM
jayderwin1's Avatar
jayderwin1 jayderwin1 is offline
Boat: MasterCraft, ProStar 190, 1986, 351.
Normal Engine Temp for 86 351PCM
can anyone tell me what the normal engine temp is for 86 351 PCM? mine fluctuates from 158 to 177 is that normal?
Old 03-04-2005, 11:17 AM
mgurley's Avatar
mgurley mgurley is offline
Boat: 2002 Prostar 197
Sounds a touch low nothing to worry about I would think. Other's will have more answers.
2002 Prostar 197
Old 03-04-2005, 11:33 AM
tph's Avatar
tph tph is offline
My '83 (same engine) runs about 165 on average.
Old 03-04-2005, 11:40 AM
jayderwin1's Avatar
does it fluctuate? if i run wide open like when pulling barefooters and bring it back down to idle the temp will rise to about 177. if i am cruising under 35 the temp will hold pretty steady is that normal? or should i look into getting a new thermostat?
Old 03-04-2005, 12:03 PM
Dan K Dan K is offline
Boat: 81 Stars & Stripes 351W and 1998 30th Anniversary LT!
I would say the fluctuation is normal and really depends on the water temp of the lake your on. This time of year the cooling capacity of the water is far better than say mid August.
Old 03-04-2005, 12:06 PM
Brn85ss Brn85ss is offline
My 85' runs right around tthe same temp as yours.Mine will just touch 175 sometimes.Check your belts my temp. started to ride just a hair higher than normal checked everything and found the belts were loose.
Old 03-04-2005, 12:33 PM
jayderwin1's Avatar
well my water temp is about 45 and in the summer it will be about 85. will that make the temp go up or will the thermostat just stay open more? my belts are pretty tight.
Old 03-04-2005, 12:38 PM
sfitzgerald351's Avatar
sfitzgerald351 sfitzgerald351 is offline
Boat: 1984 Stars and Stripes Ski 19 w/ 454
I have a 454, which also runs around 165. I've seen the temp climb a bit coming down to idle. I think the t-stat and the lower water flow take a minute to catch up to the excess heat still in the engine. I'd just make sure you don't have anything clogging up your raw water pickup or caught on the screen in the tranny cooler and that you have a new impeller. Only then would I consider putting in a new t-stat if the temp climbs much farther. A weak impeller from my experience will not pull as much water a slow speeds as a new one. Might be a contributing factor.
Scott FitzGerald
1984 Stars & Stripes w/454
Old 03-04-2005, 12:47 PM
jayderwin1's Avatar
my impeller is kind of old but looks in good shape i have a new one i have been waiting to put in a little closer to summer maybe thats what the problem is. it is normal to fluctuate though?
Old 03-04-2005, 12:48 PM
jayderwin1's Avatar
Scott did your boat come with that 454 factory?
