Old 09-01-2007, 10:20 AM
swchopper's Avatar
swchopper swchopper is offline
Boat: '05 X-Star, 8.1L, 450 HP
X-Star Prop at 6000 ft.
Can any SLC, Denver, or other X-star 450 HP owners tell me what prop they are using?
I am picking up 05 X-Star in Phoenix this morning, but taking it to my hometown in New Mexico. Lake is at 6200 feet, higher than Denver and SLC.
Thanks!
Old 09-01-2007, 11:10 AM
ProTour X9's Avatar
ProTour X9 ProTour X9 is offline
Boat: 1994 ProTour 190 & 2006 X9
Sorta a threadjack..... Why do you need different props for boats in high altitudes. (Please no flying boat comments)
If you don't fall, you're not trying hard enough.
Old 09-01-2007, 12:25 PM
Andyg's Avatar
Andyg Andyg is offline
Boat: 2008 PS197 LY6
ProTour X-9,
Engines do not produce enough power at higher elevations to turn the stock props. The reason they don't produce as much power is that there is less oxygen at elevation. Think of an engine basically as a big air pump. The more air you can get in and out of the engine the more power you will create. However the component of air that is needed for combustion is oxygen and even if you are bringing in the same volume of air there is less oxygen in it for combustion at elevation.
Andyg
Old 09-01-2007, 04:51 PM
WakePowell WakePowell is offline
Boat: Mastercraft X-Series
I have an '05 X-45 with the L-18 (450 HP) motor. I used the boat in Colorado for two seasons. Anytime I use the boat at altitudes greater than 6,000 ft I use a 17.5x19.5 prop. At lower altitudes I use a 19.5x22 prop.
It will take a few minutes for the ECM to adjust once you start it at a different altitude so don't be surprised if it doesn't run well at first.
