Old 08-31-2007, 10:11 PM
jjdiv jjdiv is offline
Boat: Albemarle 247
Tie-down opinions
Hello,
I'm about to be a 1st time MC owner--buying a Prostar and towing it 900 miles. Can you advise me on the best way to tie it down. It's on a 95 MC trailer. There are no eyelets welded on the trailer to hook in ratchet straps.
I was thinking of removing the platform and running a strap from the bunk stantions up to the transom eyes or somthing like this. I guess you could also run it under both bunks and over the gunnels (one loop)?
I would appreciate your advice--I'd really like to see a picture.
Thanks very much
Old 08-31-2007, 10:48 PM
Boat: 1998 Maristar 200VRS
Buy two ratchet straps.
Tie a strong rope into a loop about 2' in diameter.
Loop the rope around the trailer frame, attach a ratchet strap to the transom eye and to both ends of the rope.
Tighten the ratchet.
Do the same for the other side.
All done.
Old 09-01-2007, 06:27 AM
Chief's Avatar
Chief Chief is offline
Boat: 2006 Maristar 200VRS
Get straps called "Soft Straps". The hook is offset on one end so you can secure to eye without having to use the actual hook of strap on eye. They are used to secure motorcycles. Any motorcycle shop will have them. They work great.
If you don't get the soft straps at least get the one's that the hook has been dipped in plastic to prevent any oops.
2006 Maristar 200VRS MCX
KGB Ballast and all the works!
Tow Veh: 2010 Toyota Tundra
Bike: 2007 HD Street Glide
Beer:Sam Adams Boston Lager/ Cherry Wheat, Petes
Strawberry Blonde, Petes Wicked Ale
Chief Petty Officer: "Results not excuses"
"You Can't Beat a Tree"
Old 09-01-2007, 11:45 AM
flipper's Avatar
flipper flipper is offline
This is what I have, and love them. Makes it easy
http://www.overtons.com/modperl/prod...ie_Down_System
'91 prostar 190
Old 09-01-2007, 01:40 PM
Yeah, I've got the same thing, Flipper. I luv'em too.
Walmart tends to have a low-end version of the same thing.
However, I wasn't sure jjdiv would have a chance to drill 1/2" holes and tighten bolts before starting the long tow. I was just trying to help him out with a quick-and-dirty tiedown that should be pretty darned secure.
/frank
Old 09-01-2007, 01:56 PM
If the ratchet strap is long enough, you don't need loops, holes or anything like that. The hooks go together around the boat and trailer and the strap is tightened. If the strap is looped around the trailer rails and the ratchet is between the rail and the hull, it won't damage anything.
Old 09-01-2007, 02:30 PM
123src's Avatar
123src 123src is offline
Boat: 1992 MasterCraft ProStar 205
I also have them. Love them. Make it sooo easy.
1992 MasterCraft 205
2005 Chevy 2500HD Duramax 4X4 4 door 6" lift
pics at:
http://www.tmcowners.com/photopost/s...00&ppuser=3253
Old 09-01-2007, 02:32 PM
123src's Avatar
I may have postd this pic before, but you can see the strap in action at the right.
pics at:
Old 09-01-2007, 07:34 PM
When I worked for the boat dealers, we included them with every boat sold. They're pretty cheap- I don't know why all dealers don't include them, other than the obvious.
Old 09-01-2007, 07:35 PM
123src- You'll never go on plane with the trailer strapped on.
