Old 08-22-2007, 01:29 PM
surfacetension surfacetension is offline
Boat: 2007 mastercraft X 2 350 mxc
Bow scuff plate
I found a SS bow plate that surround the eye hook . to keep the boat from being scratched when I launch it. I wonder if I have to worry about the radius of the plate ? The X 2 has an almost flat profile not a sharp V like most boats?? I guess I could bend it
Old 08-22-2007, 01:33 PM
dmayer84's Avatar
dmayer84 dmayer84 is offline
Boat: Mastercraft X10 2004 5.7L
Send a message via AIM to dmayer84
Many others have carpeted the boat buddy so that it does not leave scuff marks.
_________________________________
2004 X10 Predator 5.7L
Old 08-22-2007, 02:12 PM
TMCNo1 TMCNo1 is offline
Boat: Gone
Does it come flat or already bent?
---If it's already bent and it is bent too much, lay it down on a carpeted floor, cover with a towel and place a small piece of plywood over it and gently step on it till you take enought bend out.
---If it's flat, mark the centerline of the plate with masking tape, sandwich the plate between (2) 2"x4" and c-clamp the 2"X4"'s together tight with the centerline mark along the edge of the 2"x4"'s and gently bend the plate with your hand till you match the keel angle. Simular to this, I have a drawing boad with (2) 2"x4"'s butted trogether that I use to bend small metal pieces.
Attachment 26437
Attachment 26438
Attachment 26439
Attachment 26440
Charter Member Number 1
Quote: 2RLAKE,
Old 08-22-2007, 02:22 PM
SoCalBrew's Avatar
SoCalBrew SoCalBrew is offline
Boat: 2006 X-15 5.7L 350hp MCX
Send a message via AIM to SoCalBrew Send a message via MSN to SoCalBrew Send a message via Yahoo to SoCalBrew
Anyone have any guides on carpeting their boat buddy... I'm tired of having the bb rub off on the bow of my x-15 everytime in and out.
Tom
... minds are like parachutes - they need to be open in order to function...
Old 08-22-2007, 02:47 PM
Boat: Gone
Tom
Try this thread,http://www.tmcowners.com/teamtalk/sh...ght=Boat+Buddy
Old 08-22-2007, 03:14 PM
Boat: Gone
Prior to the current notch/fitting in the hull for the shaft to exit the hull, the hull was core drilled and it left a ugly hole in the hull. I cut and bent a .040" Polished S/S sheet wedge with a 3/4" hole drilled in the front, that I mounted over the hull hole with 3M 1/2" wide black Acrylic Plus Attachment Tape, using the bending method above, that was 15 years ago and it has never come off. I also have a wedge wing over the drain plug thru-hull fitting too.
Attachment 26442
Attachment 26443
Old 08-22-2007, 04:37 PM
H20skeefreek's Avatar
H20skeefreek H20skeefreek is offline
Boat: '85 Stars and Stripes
TMC, what's the purpose?
ITCHIN' TO SKI, LET'S GO!!
1985 MasterCraft Skier, Stars and Stripes
351W with PowerSlot and Perfect Pass
Click here if you need prayer, or wish to pray for those who do.
Old 08-22-2007, 06:22 PM
Boat: Gone
It hides the ugly elongated oval core drilled hole thru the hull where the prop shaft exits the hull. Same reason MC redesigned that area with a inset notch in the hull and the shaft exits the hull from a nice hole from the stuffing box. There is a hole in the front of it to scoop and allow water to enter and keep the shaft/stuffing box cool and lubed.
