Old 02-28-2005, 02:41 PM
mika mika is offline
Boat: MasterCraft Prostar 190 1998 LT-1
Pylon Monunting Bolts
I had a problem last season with my pylon mounting bolts getting loose. Granted I have an extended pylon on at times, that I am sure is the cause. I just wanted to see if anyone know the torque specs for these bolts? I am also curious if other have had this problem also. I have been considering adding some thread locker to help keep things more reliable. I know they should be checked often but just trying to buy some insurance.
Oh yeah I have a 98 Prostar 190.
Old 03-01-2005, 12:30 PM
Tom Wortham's Avatar
Tom Wortham Tom Wortham is offline
Boat: MasterCraft, 19 FT, 1986 S&S, 351 Ford
Ensure the nuts that you are using have the nylon inserts on them. This should prevent them from backing off. I have not had a problem with mine. Used a sky high pylon (that slips over the existing pylon)... no problems yet... but ski more than I board. Goodl Luck.
Old 03-01-2005, 12:39 PM
chico chico is offline
Boat: 94 205 prostar
I Had The Same Problem With Mine.there Is A Steel Plate In The Stringer.
If You Cannot Tighten These Bolts,you Can Drill And Tap New Ones.i Also Installed Two Stainless Plates From The Pylon Mount To The Front Engine Mounts.i Have'nt Had Them Come Loose Again.
Old 03-01-2005, 04:43 PM
I can not remember if they are nylock nuts or not now.
I have a skylon slip on as well. I guess about 50/50 ski and board. I only had to tighten them once last season but I guessed on how tight. Needless to say I wrenched them down to about 150 to 180 ftlbs. I was shocked at how loose the got. Ever since then I have been hyper senstive as to the pylon attachment point and I keep a close eye on the tension cable for the skylon. When I we get some warmer weather I will look at the the nuts and make sure they are nylocks and if not I will add some.
Chico mine has U bolts that wrap around the pylon and the U bolts pass through a SS plate. I am glad to here I am not the only one that has had that problem. It scared me at first since this past season was my first with an extended pylon.
Old 03-03-2005, 02:20 PM
JohnnyB's Avatar
JohnnyB JohnnyB is offline
Boat: 2004 Prostar 190
Can you post some pics of this setup??!!!!
2004 Prostar 197, ACME 843
Old 03-04-2005, 11:31 AM
johnnyb
the boat is in storage right now.if your really interested in streghtening your pylon i could take some shots of it.the angle iron crossmember kept coming loose.
Old 03-04-2005, 04:33 PM
johnnyb stringer pics...
Left side...
top view...
Tied into motormount
Old 03-05-2005, 02:18 PM
JohnnyB's Avatar
Chico,
Thanks for posting the pictures!!! I may start with re-taping the holes in the stringers. For the pieces that attach at the motor mounts, did you have to move the motor mounts away from the stringers to accommodate the flat stock underneath them, or is that gap there already?
Thanks again.
Old 03-05-2005, 06:56 PM
johnnyb\
the gap is already there.if it is too big you can shim it.my pylon hasn,t budged in 2 years.
Old 03-05-2005, 09:29 PM
Jim@BAWS's Avatar
[email protected] Jim@BAWS is offline
Pylon
As a Dealer this would be a GREAT SALES TOOL. Nothing to hide in a MC Try doing what you are doing in a BU. Heck it probably would have come out of the boat already. Pictures are worth a 1000 words In the case of a MasterCraft 1000s of dollars
[email protected]
