Old 02-28-2005, 10:14 AM
rasmithaz rasmithaz is offline
Boat: 99 Prostar 205
Can't get in nuetral
When the transmission is in nuetral it is still spinning the prop shaft. I disconnected the transmission cable to insure the transmission was in the nuetral position and it is. This is not intermittant free spinning. Any ideas?
Old 02-28-2005, 10:29 AM
BrianM's Avatar
BrianM BrianM is offline
Boat: 1988 Prostar 190
Do you see absolutely no difference between neutral and in gear or is it just 'creeping' (maybe turning 1/4 the turns it is in gear)?
Old 02-28-2005, 10:31 AM
east tx skier's Avatar
Boat: 1998 Ski Nautique
This was explained to me the other day, but when they get older, the clutch plate (or something) gets a little warped, and causes the prop shaft to spin a bit when it's in neutral. My SWCC mechanic described it as absolutely nothing to worry about.
If I've got my parts mixed up, someone please correct me (politely)
Previous: 1993 Prostar 205
FAQ
Be kind. Have fun.
Old 02-28-2005, 10:47 AM
I see no difference... that prop shaft is not creeping. I discovered this out of the water so there is no water resistance. This is a 'new to me' 93 prostar 205 with a 1/1 model 1017 borg warner. Put my mind to ease East texas on this one....summer is creeping up and I keep finding things to fix.
Old 02-28-2005, 11:18 AM
In my situation, whether in the water or on the hose, when I first start it up, the shaft will start turning. It bothered me until an inboard mechanic I trust told me that they all do it and that I shouldn't worry about it. I don't know if your boat is doing the same thing, but a lot of the older boats do what mine is doing.
FAQ
Be kind. Have fun.
Old 02-28-2005, 12:05 PM
jayderwin1's Avatar
jayderwin1 jayderwin1 is offline
Boat: MasterCraft, ProStar 190, 1986, 351.
will your boat go into reverse? and if and when it does, does it clunk real hard?
Old 02-28-2005, 12:11 PM
BrianM's Avatar
The reason I asked is because my brand new transmission creeps a bit when it is in neutral. When on the trailer I would say that the prop is probably turning about 200 rpm or so. Goes into and out of both forward and reverse as smooth as silk just has a bit of a creep. My mechanic says that this happens sometimes with the new transmissions as the clutches are still a bit 'tight' and the creep should lessen with some hours on the water. At first it bothered me but now I barely notice.
Sounds like yours may be due to what EastTexas said. If it is clunking into or out of gear though you may have additional problems.
Old 02-28-2005, 12:16 PM
bret's Avatar
bret bret is offline
Yes they can all do this from time to time and I bet if more of us had the boats out of the water and fired them up on "fake-a-lake" or similar, we would see it more often. You might try, if not already, changing the tranny fluid and see if that helps. My boat has done it on occasion too. It did it one day on the fake a lake, I reached up and just barely grabbed the shaft in front of the strut and it stopped; it didn't start again after I released it...just one of my experiences.
Old 02-28-2005, 12:32 PM
The transmission fluid is fresh and is at the proper level. The transmission works fine in forward and reverse without any big clunk when engaging. I tried to grab the shaft and it didn't stop so I backed off because I need my arm and hand.
