Old 08-06-2007, 09:54 PM
Mike's Avatar
Mike Mike is offline
Boat: Mastercraft, MariStar, 2002
Driving with or without the cover?
I have trailered my 1990 Maristar 210 thousands of miles without a cover and last summer I upgraded to a 2002 Maristar 230 with factory tower. Twice the center rear seat cushion has flown out of the back of the boat as I was driving. (yes the snap was fastened before we started to travel)
This last time driving on Vasco Road and only going about 50 MPH but with some gusty winds. I saw the seat lift up in my mirror so I slowed to about 40 looking for a place to pull over and we came around a corner and another gust took it right over the back of the boat into traffic. I pulled over and ran back and picked it up before anyone could run into it. Placed it back in the boat and made sure the snap was fastened and took off again. No more than a mile down the road we started an uphill grade through a little canyon and again the wind picked up and lifted the seat cushion and blew it right out of the boat again. I pulled over at the next clearing and started walking back to pick it up. About half way there a gust of wind picked it up off of the road and started making it tumble down the highway away from me. I finally picked it up about a 1/4 mile from the truck and started back clutching the cushion under my arm so the wind wouldn’t blow it away again. We ended up putting all of the cushions in the truck so it wouldn’t happen a third time.
So, what do you guys do? I can't imagine trailering again without doing something else. Even if it means driving with the cover.
Old 08-06-2007, 11:06 PM
Maristar210's Avatar
Maristar210 Maristar210 is offline
Boat: paddle
I too feel your pain. I now remove all the cushions from the boat and put them inside the truck. I have chased a cushion I wanted to rescue out onto the freeway in an effort to not have it destroyed. Not cool from a safety standpoint thus the elimination of the cushions in the boat. NFW I'm doing that again, ever....
Old 08-06-2007, 11:09 PM
dpolen's Avatar
dpolen dpolen is offline
Boat: Med Blue 2012 X2, Illmor 5.7
Send a message via MSN to dpolen
How about a snap-on cover, those are generally pretty trailer-friendly? I have tried trailering mine (not a snap-on) and will never use that cover again as it ended up scratching the heck out of my boat when it came a little loose. Hope this helps, sorry about your bad luck with the seat blowing out...I have a pretty similar boat, have never had any issues with my seats blowing out even at 70+ mph on the highway.
Mediterranean Blue 2012 X2
2013 Ford Expedition EL Limited
He who dies with the most toys wins...I'm losing right now!!!
Old 08-06-2007, 11:16 PM
WTRSK1R's Avatar
WTRSK1R WTRSK1R is offline
Boat: 2004 MasterCraft ProStar 197
When I had my '92 205 the dealer told me to never trailer it with the back seat cusions (there were 3) installed. He said there were many reports of them blowing out of the boat. I never once drove to the lake with them in. On the flip side, I did forget to put them in the truck once and all there was to sit on was the styrofoam wedge back seat.
My 197 does not seem to have this issue. Even without the snap cord attached it would be nearly impossible for that to blow out.
A positive attitude may not solve all your problems, but it will annoy enough people to make it worthwhile
2004 Prostar 197 - Red on White
350 TBI, Perfect Pass, Heater, Shower and a whole lot of fun!
Old 08-06-2007, 11:23 PM
Leroy
I guess I've been lucky, but never had it happen and I rarely have the snap closed. That is a heavy cushion, unless they lightened it after 2001.
I would just take it out and put it in the storage beside the engine.
Old 08-06-2007, 11:26 PM
79stars&stripes
it would be an expensive day if you end up ripping a cover, however it would also be expensive if you end up loosing a seat. I think that putting the seat cushins in the truck and trailering without a cover is your safest bet.
Old 08-07-2007, 10:09 PM
bdecker's Avatar
bdecker bdecker is offline
Boat: 2005 Tournament Team 197, MCX
Bimini boot
I tend not to drive with the cover on the boat, but I do drive with the bimini folded. Apparently the boot cover decided to leave at about 70 MPH on my way home from the pond tonight. Luckily it appears the bimini itself was not harmed, but I guess I'll be looking for a new bimini boot cover. Definitely check this thing often if you trailer with it, as mine even had straps on the side and still broke lost. The bimini made an awful racket until I could pull over, but it appears unharmed... Anyone know where to get one of those covers?
Old 08-07-2007, 10:15 PM
dmayer84's Avatar
dmayer84 dmayer84 is offline
Boat: Mastercraft X10 2004 5.7L
When I trailer my boat I put my wakeboard in front of these cushions so that the board pushes the air up and over the seats, or at least I would like to think so. Havent had a seat fly out yet.
Old 08-07-2007, 11:59 PM
jcbatt's Avatar
jcbatt jcbatt is offline
Boat: 2017 MasterCraft X-23
I had a Rankin towing cover made for my boat (http://www.rankincovers.com/) and it works great. Besides the benefit of keeping the boat and gear from blowing around, I also found that I get about 10-20% better gas mileage when towing with the cover on. For 1/2 hour trips, I usually leave it uncovered, but for anything longer, I generally use the cover.
2017 MasterCraft X-23 - 6.2L, Loaded; Available for sale now!; More info at http://www.kentroad.com
Old 08-08-2007, 02:47 PM
bbeach's Avatar
bbeach bbeach is offline
Boat: 1990, Prostar 190, 351 Indmar
I tow with my factory cover, however its been reinforced in the rub areas to handle trailering. I also twist the straps so they don't flap around and wear on the hull... I've seen people use tennis balls to keep the straps off the hull if needs be.
KStateSkier
"Le ore del mattino hanno l'oro in bocca"
The morning hours are the most precious of the day!
