Old 07-31-2007, 03:56 PM
floridamastercraft floridamastercraft is offline
Boat: mastercraft
Air Conditioning Garage
I live in the south (florida) and heat and humidty come free with every garage.... my garage is 28x20 (560 sq ft) ... I have no windows either...
I have a portable ac unit now but it can't keep up...
I thought about a mini-split or putting a vent from the house ac in there to put in cool air...
I put the boat in there almost every day wet so there is alot of humidty in there..
anyone have any ideas?
Old 07-31-2007, 04:03 PM
peason's Avatar
peason peason is offline
Boat: MC, 209, 2002, 310 HP
Do you have ceiling fans in the garage - It will help to get the air moving as much as possible.
Old 07-31-2007, 04:06 PM
Boat: mastercraft
yes i have ceiling fan.....
Old 07-31-2007, 04:20 PM
Jkelly's Avatar
Jkelly Jkelly is offline
Boat: ProStar 197 2004
You will have to insulate your garage for it to any good. It also depends on the size of A/C you have.
Jason Kelly
Old 07-31-2007, 04:23 PM
Boat: mastercraft
I did insulate the garage ... ceiling, garage door and it has block walls...
Old 07-31-2007, 04:24 PM
Maristar210 Maristar210 is offline
Boat: 04 210 Maristar
http://www.acwholesalers.com/shop/li...asp?brand_id=7
Old 07-31-2007, 04:54 PM
rspiecha's Avatar
rspiecha rspiecha is offline
Boat: 1994 Prostar 205/2005 Maristar 210 VRS - MCX
Do you have a place to put in a PTAC unit??? The style used in motel rooms, all in one unit, 15k btu is around $700, works great for our insulated 30x26 garage. Has the ability to heat, but probably not needed for you.
http://www.ptacs4sale.com/
Rob
2005 MariStar 210VRS - MCX - ACME #845
1994 Prostar 205 TBI 350 (previous boat)
2007 Sierra Classic 2500HD Crew Cab
Duramax/Allison 6 speed
War Eagle
bigmac bigmac is online now
Boat: 2004 Maristar 230 VRS
Originally Posted by Maristar210
Those things are great. Only requires a 3" hole in the wall to mount the condenser unit and they are FAR more efficient than a window unit. A buddy just built a house after tearing down the one that used to be there. The old house had about 5 of those units scattered around. He went with central air in the house and we installed the leftover units in his garage. We had to wire for 220 for the compressor, and used the compressor connection to power the condenser, which was also 220. That was simpler, but there were some NEC issues we had to ignore. We also had to get a regrigerant guy in to charge the lines. Very cool units.
'04 MariStar 230VRS/MCX
Old 07-31-2007, 05:38 PM
etduc's Avatar
etduc etduc is offline
Boat: Mastercraft Prostar 205
Unless you want more humidity, hydrocarbons, etc. in your house. Do not install condition air supply, from your house.
The simple size calculator, will approximate cooling needs for an attached room, but not a garage. There is more infiltration (leaks) in a garage install.
What temperature, do you want? And at what humidity level? Most importantly, how much do you want to spend?
If you give me your, actual location (nearest big city) I can give your the Manual J load info.
Ayyyy!
1994 RED Mastercraft 205, Chevy 5.7 TBI.
Old 08-01-2007, 05:47 PM
Boat: mastercraft
Rob...HOA won't let me install a PTAC
etduc... I would like to get it in the high 70's or mid 70's.... humidity level I would like to get it around 50% or less so mold and stuff don't grow and rust stuff.... I do work out there couple of times a week....
I'm near West Palm Beach....
