Why doesnt mastercraft do somthing like this for their ballast
PureVert Wake System fills in under a min and empties in just seconds? just curious as to why they have not designed somthing like this for their boats
Quote: Originally Posted by Hoosier Bob She always misses me and when I turn her on it is hard to turn her off! She is MC and she completes me! She is the first ride that wants it as much as I do!
speaking of ballast. sorry for the thread jack. All of my gauges read 1/2 full when they are in fact empty. I know others have had a problem and is there any easy fix that solves this problem. In other words can the gauges actually be accurate at all?
I have an 07 X2. |
Roonie, I have an 06 X2 with the same problem. After researching a little i found out that each of the tanks have an electronic sender atop each of them. If you remove the three screws from the access panel on the Starb. and Port inside your storage compartments, you will see the electronic sender. There are two set screws that have some gunk on each of them to keep them from moving. If you scrape off the gunk and use a small screwdriver you can set these the tank level to match the guages. There are two (plastic) screws... one for empty calibrationa and one for full. Turn on your ignition and you can see the changes to the scew positions on your guages. Mine get off a couple of times a summer.
The KGB (center) tank sender is under an access panel inside you passenger seat storage. Slide it to the side and you will have the same access as in the back. |
yes but it only has like 700lbs doesnt it???
I've got the same problem in my 197. I assume the electronic sender is the same for this type of ballast?
2004 Prostar 197 TT, MCX 350hp, PowerSlot 2006 HO Nitro |
That systems says it fills without any pumps? How does it work? How does it discharge the water?
2006, X-45, Acme 1285, X-Star ballast, Heater, Shower, |
#7
pro v.......
Sometimes when I reflect on all the beer I drink, I feel ashamed. Then I look into the glass and think about the workers in the brewery and all of their hopes and dreams. If I didn't drink this beer, they might be out of work and their dreams would be shattered. -- Babe Ruth |
#8
The pure vert has a gate on the hull of the boat that is opened and water rushes into the space between the outer hull and the inner hull. The trapped air is released somehow but I am not sure, I own a Mastercraft. The system drains in similar fashion but only when underway. From what I understand the boat has to be on plane and at speed for the system to drain.
A lake carries you into recesses of feeling otherwise impenetrable. ~William Wordsworth Funny, it's almost like ol' Wordsworth owned a Mastercraft! |
#9
Sounds like a really good idea...must feel really strange the first time you use it...
Oh, and who you callin' a pervert? |
#10
