Old 02-21-2005, 09:49 AM
PeteS's Avatar
PeteS PeteS is offline
Boat: 1988 Prostar 190 - 351 Indmar (1:1) / 365 Hours
Oil Changed - 6 Quarts Drained
I just finished a long, but successful oil change over the weekend in my '88. You guys probably won't care as much as I did, but I thought I would share, the bozo before me who owned the boat had over 5.5 quarts of oil in it!
I just finshed reading a thread regarding the capcity being right around 4, and I managed to drain 5.75 right out of the bottom of the oil pan & filter - no pump. I wonder if that was the reason the boat wouldn't go over 36 ?
He had the filter on so tight I broke my filter wrench, and had to drive a 1/2 socket extension through the center to get any torque to twist it off. Sorry to whine, just venting a bit.
1988 Prostar 190 - 351 Indmar (1:1) / PerfectPass Digital Pro 6.5n, 13 x 12 Acme 3-Blade
Old 02-21-2005, 01:41 PM
phecksel phecksel is offline
Boat: '03 197
I seriously doubt the proper oil level is four qts. Five or six would be the proper amount. 5.5 is possible if the original engine call for a long oil filter and five qts and the owner put on a short filter.
Old 02-21-2005, 01:56 PM
PeteS's Avatar
Thanks for the resopnse. This board is a great resource, because typically there is someone on here who has had the same issue as you in the past, or at least knew of someone who has.
The thread below talks about how it is very difficult to get all of the oil out when draining or pumping, and people with years similar to mine only seem to be able to get around 4 quarts. The fact of the matter is, I got almost 6 quarts out, and who knows how much was still in the bottom of the pan. But I do agree, the first time you hear 4 quarts for a 351 Ford you think twice:
http://www.tmcowners.com/teamtalk/showthread.php?t=1210
Old 02-21-2005, 04:19 PM
Brn85ss Brn85ss is offline
My ford will hold about 4.5qts.Every one I talk to about this says the same about 4-4.5qts.
Old 02-21-2005, 04:39 PM
Boat: 95 PS 190 EFI
Are you sure it was all oil? I once had a mechanical fuel pump get a diaphram leak, which put gas into the oil.
Just something to look at/smell.
If one day you're asked:
Will you say:
It's time to SKI.
Old 02-21-2005, 06:55 PM
AirJunky's Avatar
AirJunky AirJunky is offline
Boat: Former Prostar 205 owner upgraded to an 05 Malibu vRide
If you had a qt & a 1/2 over, it should have blown seals or spewed out the valve cover breather or PVC valve, at least registered high on the dipstick. It's been a while since I had a 351 so I don't recall how much oil they held, but it would have been causing problems.
Old 02-22-2005, 10:29 AM
PeteS's Avatar
Thanks for the feedback! Now this is really getting concerning! I didn't notice any gas in the oil, or in the pan after draining fortunately.
The drained oil sat in the pan for about 3 hours, and if there was fuel in there you would have thought it would have seperated out by then. Plus there was no fuel odor, just stagnent oil.
You have a good point, Airjunky. I'm not sure what's going on at this point. I just know the pan was reading 5.75 quarts, and most on here are stating that this era of marine 351W's have capacities of around 4 to 4.5 quarts -- maybe it was just a the verge of spewing/overflowing. Thanks again.
Old 02-22-2005, 12:18 PM
east tx skier's Avatar
Boat: 1998 Ski Nautique
Haven't read the rest of the thread, but depending on filter (long vs. short), 5.5 isn't unusual. That's what I pulled out of mine last fall (dealer had done the last oil change). Zero mechanical issues last season.
-Bozo
Previous: 1993 Prostar 205
FAQ
Be kind. Have fun.
Old 02-22-2005, 12:21 PM
Boat: '03 197
http://www.indmar.com/files/manual/indmar_2001_om.pdf
Page b-2 states 5.5 qts with filter change. Now that is for the newer chevy engine, but I can't believe the 351 would be any less. I used 6 qts in my 88 tristar with a long filter. Should be the same engine.
Old 02-22-2005, 12:25 PM
PeteS's Avatar
Please help me, BrianM! I'm getting eaten alive over here ! Could it be that maybe I was wrong for jumping to conclusions? My world is crumbling to pieces !
