Old 02-20-2005, 09:01 PM
milkmania's Avatar
Boat: White/Red 91 PS 190
questions regarding distributor
my 1991 prostar 190 won't start
351 carbed Indmar.
I've not dug deep enough to see if it's getting spark from the contacts, but I read about so many recommending getting away from the contact type distributor.
there seems to be two electronic kits that get mentioned quite a bit....
I think Perktronics and something else.
my questions are:
(a) to switch over to electronic ignition, do I needto replace the distributor or just install the electronics to the old distributor?
(b) do I need to go to the 8 mm wires also?
(c)will a regular 351 distributor & coil work? I realize the need for marinization.
I remember an ol' 69 Nova I had, we put an HEI distributor on it, very simple...
Install distributor, run new plug wires, twist two wires together, and fire it up!
Old 02-21-2005, 07:02 AM
Boat: 95 PS 190 EFI
You'll use the stock distributer, wires & (most of the time), coil. However, I hear that sometimes a new/different coil is required.
call Vince at www.skidim.com - he'll answer any questions you'll have. They really know their stuff. Their prices are decent also.
If one day you're asked:
Will you say:
It's time to SKI.
Old 02-21-2005, 07:54 AM
BrianM's Avatar
BrianM BrianM is offline
Boat: 1988 Prostar 190
Ditto, but the only reason you would need a new coil is if the one you have is weak anyway. Besides that just take the points out, install the electronic (takes 20 minutes max) and your done. Best $99 you'll spend.
Old 02-21-2005, 08:11 AM
BriEOD's Avatar
BriEOD BriEOD is offline
I did this last summer and Brian is correct. Check out this link it has step by step photos and directions.
http://classifieds.mastercraft.com/m...tml?1090685505
Old 02-25-2005, 12:47 PM
milkmania's Avatar
well.......
now that I've read that thread, ordered the part from pertronix, looked at my distributor, and figured out that mine's already been changed out.
oh well...good thing I kept the receipt and didn't open the box
Old 02-25-2005, 01:01 PM
Ski-A-Rees Ski-A-Rees is offline
Boat: Mastercraft Prostar 1989 w/ Chevy Big Block 454
Send a message via AIM to Ski-A-Rees
As of last sunday I'm takeing my electric ignition off and going back to stock! I don't know if you ski in salt or fresh water but it has been even worse for me! Last sunday I was having alternator trouble and it was running at 11.5 amps which screwed up the electric ignition and the boat ran like crap! It almost sounded like it wasn't running on all cylinders it was so bad!
Old 02-25-2005, 01:12 PM
BrianM's Avatar
Very interesting. I thought that the electonic ignition wanted the full 12v instead of a resisted 8v or so.
Me thinks you have another issue...............
Old 02-25-2005, 03:21 PM
Storm861triple Storm861triple is offline
Boat: 1992 Mastercraft Prostar 190
The first thing you need ot do is diagnose why your engine won't run. THEN decide if you want the benefits of Electronic ignition.
You had other issues. Electronic ignition should work absolutely fine at 11.5 volts. It should work fine down to about 8 volts.
Thomas Kendrick
'92 PS 190
Old 02-25-2005, 03:39 PM
jsonova99's Avatar
jsonova99 jsonova99 is offline
Boat: 1991 Mastercraft Prostar 190
Milkmania,
I couldn't get my '91 to start last weekend, all I did was spend about $10 on new plugs. I let it sit all week and just tried it this morning. Started up immediately. My guess is that you probably have a similar problem. I have a new cap and rotor coming from skidim to finish the job, but the plugs alone seemed to do it.
1991 Prostar 190 - Ambush 4 blade prop
Old 02-28-2005, 11:50 AM
milkmania's Avatar
Originally Posted by jsonova99
Milkmania,
hmmm.....I'll keep that in mind.....
when this freaking fracking wet weather pushes through
