Boat Died, Need ideas???
Hey guys I was out towing in a Sea Doo that grenaded tonight and after towing it slowly, out of the blue, the boat motor dies. I was shocked. I put the boat in neutral and cranked it over with no luck. I waited a second or five and tried again and she fired. It ran well with no other issues the rest of the night.
I know its a crap shoot but I thought you guys might have some ideas of what to check? 175 hours on a RTP 315hp |
Oh, wait...never mind. Did it die like a neutral switch got bumped, or did it kind of wind down like fuel starvation?
'04 MariStar 230VRS/MCX |
Did the motor die like it was running out of gas? or like you turned the key off?
I rather be waterboarding
I was standing in the center of the boat with one hand on the wheel when it died, no where near the laynard but it died like someone pulled it off. Thanks in advance.... Steve |
My first thought would be something in the ignition circuit, like a loose wire or bad ground. I'd start by climbing under the dash and making sure all the wires on the ignition switch are screwed down tight and none might be shorting out. Also, no loose wires on the lanyard cut-off. Then I'd go back to the engine and check the wires on the main engine electrical panel (whatever that is, and wherever it's located). Then, I'd tighten the battery terminals. Then, I'd just use the boat, but I wouldn't go out without a cell phone and a paddle.
I had that problem intermittently on our simple ol' Boston Whaler with a 35 horse Johnson. Took me forever to find it - turned out to be a broken wire in the middle of the electrical harness that runs from the console to the motor. I think somebody dropped a 6 gallon fuel tank on it but there were no visible marks on the harness loom. Doncha just love boats?
'04 MariStar 230VRS/MCX Last edited by bigmac; 07-11-2007 at 09:13 PM. |
Maybe it had a momentary upchuck knowing it was tugging a PWC!
Charter Member Number 1 Quote: 2RLAKE, At some point in time people need to wake up, remove their cranial intrusion into their own rectal areas, and take responsibility for their own actions. |
#7
Will do BigMac thank you.
TMC - This guy is someone I kind of know from seeing him around. He works for a shop that sells the damn things. It was one of those supercharged ones that scream. He said it went BOOM and would not turn over afterwards. One less on the water ![]() |
#8
I have been thinking of converting them one at a time to turbine or rocket power and attempting to reach the moon with them. Would it work? After all, it would all be done in the name of Science. You know, like Benjamin Franklin, the guy who has all those craft stores, that caught lightening in that 2 liter Coke bottle on a kite string in a hurricane!
Charter Member Number 1 Quote: 2RLAKE, At some point in time people need to wake up, remove their cranial intrusion into their own rectal areas, and take responsibility for their own actions. Last edited by TMCNo1; 07-11-2007 at 09:25 PM. |
#9
Happend to us just last weekend and we still cant figure out what happend so when u get an answer im just going to assume that is what our problem was to
What do u call a life dedicated to hockey and mastercrafts i call it a time well spent 96 Red Prostar 190 with only 120hrs |
#10
It's running again, be happy!
I can't think about what could have been situations! |
