Old 02-16-2005, 01:18 PM
DanC's Avatar
DanC DanC is offline
Teak transom saver
So I bought a piece of teak at the lumberyard and had the guy rip it at an angle and viola two transom savers at ľ the price. Now Iím looking for some advice on mounting it, where and how.
Old 02-16-2005, 01:19 PM
DanC's Avatar
The 209 has a transom that sticks out and gets scuffed up regularly by newbies. I figure the saver needs to be even with the outermost part of the transom to be effective. Do I leave the saver straight or do I curve it to match the contour of the transom?
If I curve it, it will cross over one of the teak platform joints. Will that be a problem with cleaning, oiling and maintenance or should I just ignore it?
How should I attach it? I was going to use countersunk SS wood screws, but then I thought about SS through bolts. West Marine sells teak hole plugs. I could put plugs in to cover the countersunk screws. Or will I regret that at some time when I might need to remove the transom saver?
Old 02-16-2005, 01:24 PM
ski_king's Avatar
ski_king ski_king is offline
How about putting the screws thru from the bottom up. Then the screws will only show to the fishes.
Drill a slightly oversive hole thru the platform then clamp the saver in place and transfer the holes into the saver and predrill blind pilot holes.
Keeping it straight will probobly look better IMO.
Old 02-16-2005, 02:44 PM
jayderwin1's Avatar
jayderwin1 jayderwin1 is offline
Boat: MasterCraft, ProStar 190, 1986, 351.
whats the deal with these transome savers? are they supose to keep idiots from wacking the transome with there skis of wakeboards?
Old 02-16-2005, 02:54 PM
Mag_Red's Avatar
Mag_Red Mag_Red is offline
Boat: 2004 Prostar 209
Yeah.......how is a piece of wood only 1" high going to keep the tip of a ski from hitting the transom??? I like the clear plastic thing I saw on here better.
Old 02-16-2005, 03:07 PM
erkoehler's Avatar
I would put both on. Never to much protection from some idiot who knocks the fiberglass.
Old 02-16-2005, 03:12 PM
ski_king's Avatar
I havent had much problem with this as I usually put my ski on in the water or on the dock if I am doing a dock start. When I do put the ski on when on the platform, I make it a point to keep the ski away from the boat.
I can see with wakeboards and some of the newer binding, it may be close to impossible to get in the bindings in the water, so I can see where the transom saver is can help.
I can also see where the clear plastic sheets can save scratches, but I am not sure if it will protect it from a good whack.
My boat has the tie up eyes or lifting eyes, what ever you call them right above the platform and seem to protect the transom, no scratches or nicks yet, maybe I have been lucky.
Are there transom protectors available for the fibergalss platforms?
Old 02-16-2005, 03:58 PM
east tx skier's Avatar
Boat: 1998 Ski Nautique
Dan, I received a transom saver as a gift from a very generous board member. I attached it with composite, rust-proof decking screws. I drilled pilot holes from the bottom of the platform and attached it to match the curvature of the piece of platform closest to the transom. You can't see the screws and it looks fantastic. I used enough screws all the way across so it doesn't have gaps. I have never had a concern about it coming lose.
I oiled everything up before installing it.
Many thanks to my benefactor.
Previous: 1993 Prostar 205
FAQ
Be kind. Have fun.
Old 02-16-2005, 04:08 PM
G-man's Avatar
G-man G-man is offline
Mine is mounted like Dougs on my boat from the dark side. See photos in profile. I use mine to rest the front edge just behind the tip of ski against when I am putting it on that way it won't slip towards the boat.
06 AWSA Approved Towboat
Old 02-16-2005, 06:03 PM
John B's Avatar
John B John B is offline
Boat: ProStar 190 1996 LT1
Here is a picture of the one on my boat.
