Old 06-26-2007, 08:01 PM
russfortin's Avatar
russfortin russfortin is offline
Boat: 1987 mastercraft prostar 190 ford 351 / 2002 Prostar 197TT
oil pressure
I'm posting like crazy now, love this site!
I have one other problem in my 87 prostar. When i initially start the engine i get an oil pressure around 60 or so and over the next five minutes it eventually goes down to about zero and stays there. Everytime i shut the engine down and restart throughout the day, it'll be back up at 60 or so for a few more minutes. Theres no engine knocking or anything to make me believe that the guage is correct and there is no oil pressure. And, it might not be good, but i've run it almost everyday for a year now with this problem.
any pointers on what to check, maybe something in clogged??
Thanks
Russ
Old 06-26-2007, 08:13 PM
M-Funf's Avatar
M-Funf M-Funf is offline
Boat: 1976 Mastercraft Stars & Stripes 351W
Since the gauge is probably an electric, you could check the sender...heck, might as well just replace it and see if that works. If you put a new sender on and you still get Zero, then you should hope that it's a bad gauge...
M-Funf (a.k.a. Jeff)
Our '76 Stars & Stripes
Canis meus id comedit
Old 06-26-2007, 08:34 PM
russfortin's Avatar
where is the sender located? what does it look like? should be no problem to replace it, just not sure where, thanks
Old 06-26-2007, 08:57 PM
M-Funf's Avatar
Attached to this thing somewhere...
Sorry...Sorry...I couldn't resist
I'm not exactly sure. It may look something like this with one wire attached to the top...
Skidim has them for 30 bux...
http://www.skidim.com/prodinfo.asp?number=R020001
Old 06-27-2007, 10:23 AM
85S&S_Keuka 85S&S_Keuka is offline
Boat: 85 S&S Power Slot, 351W, Blue/Grey
Yep, that's what it looks like. It's on the port side of the engine (assume you have a 351), above the oil filter. Mine was good enough to show somthing on the gauge if the pressure was above 50psi, but once it warmed up enough to drop below that, it would read 0.
Old 06-27-2007, 10:56 AM
P-hat_in_Cincy's Avatar
P-hat_in_Cincy P-hat_in_Cincy is offline
Boat: MasterCraft Prostar 205V "wakeboard edition", 2004
Agreed with the picture above. Just fyi...Since mine is original, it's painted black along with the rest of the engine/components.
2004 MasterCraft Prostar 205v 'Wakeboard Edition'
Old 06-27-2007, 12:08 PM
cwright's Avatar
cwright cwright is offline
Boat: MasterCraft Prostar 190 1988
I had bouncing oil pressure last year causing my low oil alarm to chirp when it bounced below 10. I replaced the sending unit and problem went away. Be forewarned however, the 1/4" nipplle that screws into the block will probably break off. Mine did and I've read others post that theirs did too. Don't do this without a hardware store nearby to resupply the 1/4" fittings that get mangled in the process. Good luck.
Old 06-27-2007, 07:07 PM
MIMC's Avatar
MIMC MIMC is offline
Boat: 2000 Prostar 195 w/ LTR
I agree with all the posts so far, replace the sending unit. If the problem still exists I'd recommend attaching a "wet" oil gauge to check psi. The gauge will screw in right where the sending unit would be. A good gauge won't lie. Also, psi will be higher when the engine is cold - once at operating temp psi will drop.
A good friend will come and bail you out of jail...but, a true friend will be sitting next to you saying, "Damn...that was fun!"
Old 06-27-2007, 07:15 PM
M-Funf's Avatar
Another idea would be to install a "tee" at the block so you could attach the sender and a remote "wet" pressure gauge. That way, you can compare the dash gauge with the "wet" gauge.
Old 06-28-2007, 02:50 PM
bowtie355's Avatar
bowtie355 bowtie355 is offline
Boat: Mastercraft, Stars & Strips, 1985 , 351 PCM, heater
My 85 SS did the same, I replaced the transducer and the gauge works normal.
Dan
1985 SS Mastercraft,OJ 14x18 Prop, heater and a cup holder.
www.vetteworksonline.com
