  #51
Old 05-07-2013, 12:07 PM
tonyvisone tonyvisone is offline
Boat: 2002 MC Pro Star 197
Originally Posted by trunderw View Post
On my old 190 I had to use a grease gun with the zerk fitting and I didn't have grease laying around as much as you have in your pic. Did you put grease on by hand or did you use a grease gun?
i put in on by hand. i could not find any zerk fittings....
is there a spot to grease up by the steering wheel as well?
anybody know anywhere good for cheap quality steering cable? or a part number?
also, as far as a new cable, where would i grease it correctly as periodic maintenance? did i grease my current cable correctly? as i said, i did not see any fittings...
Old 05-07-2013, 12:39 PM
JerryW's Avatar
JerryW JerryW is offline
Boat: 2002 X-9; LQ9
On our 2002 209 / X-9 which is a similar boat, there is a bracket in the bilge where the steering or rudder cable is mounted. There is a grease fitting on it, and another on the metal tube that the cable runs through. You would probably need to pull up the access panel in the floor behind the motor box, and get down real low to see them. They are probably under the forward part of the gas tank. I've also seen grease fittings on the steering box behind the dash on some boats we've owned.
"Horsepower is a terrible thing to waste"
Old 05-14-2013, 10:19 AM
is there a grease fitting on mine that i was not seeing?? i didnt see any thats why i greased the way i did.
anybody have a part number, or know where to get one?
Old 05-14-2013, 12:03 PM
FlyHighorDie FlyHighorDie is offline
Boat: 2003 X-9
I just replaced mine you can check out my thread which isn't specific to the fix but I gave some details.
http://www.mastercraft.com/teamtalk/...t=53412&page=2
The grease zirk is on there or fell off. I am guessing if the cable is stiff its time to replace. I paid $125 on ebay.
part number ssc13419
