Old 06-07-2007, 10:33 AM
bigmac bigmac is offline
Boat: 2004 Maristar 230 VRS
Originally Posted by fintek9
I don't have my manual with me right now but it states taking tranny fuild dexon(?) 3 "GM" rated!? i believe! 01 x-star w/ hurth 1:5:1
There were complaints of noise at idle with some of Hurth's V-drives when they were using ATF, so they recommended people switch to 15W40, same as the engine's oil. Either will work just fine. If you call Hurth today and ask them what you should use in your V-drive, they'll tell you 15W40 engine oil (at least that's what they told my dealer).
Water in ATF looks like a strawberry shake, water in engine oil looks like cafe-au-lait.
'04 MariStar 230VRS/MCX
Old 06-07-2007, 10:46 AM
fintek9's Avatar
fintek9 fintek9 is offline
Boat: 2001 x-series x-star vortex 350, 310hp
hummmmmm....gotta look on mine, over this one!!
very interesting...
Be smart, but don't show it!
Tim
Old 06-07-2007, 10:51 AM
fintek9's Avatar
that was it... ATF, I knew I was wrong on that one...I don't have a noise or at least i did'nt, did'nt have a chance to take it out last night after i got it home! will tonight thou....
Tim
Old 07-28-2008, 04:23 PM
lav's Avatar
lav lav is offline
Boat: mastercraft,2002,x star,5.7L indmar
Ok so if I understand this correctly it is ok to run 15w40 in tranny also
ZF Hurth 63 IV-1.6
2002 Xstar
Haven't had any noise just would make it alot easier to only have to use one fluid
Thanks for any help
Greg
If it wasn't dangerous it probally wouldn't be fun.
Old 07-28-2008, 11:48 PM
ZF Hurth 63 IV-1.6
2002 Xstar
Thanks for any help
Greg
That's the same transmission I have and it came from Indmar with 15W40. To be on the safe side, I'd call Indmar before making that fluid switch.
Old 07-29-2008, 05:11 AM
lav's Avatar
lav lav is offline
thanks bigmac I will give them a call today and double check
Old 09-29-2013, 11:26 AM
chevyluv chevyluv is offline
Boat: 2001 x star
i had this today as well. bought the boat this year. was checking the transmission fluid while looking at a few other things for winterizing it and noticed mine was bright yellow. it didnt look separated though it was a single consistency and the boat has sat for a litle over a month now.
Old 09-29-2013, 11:37 AM
If oil that was clear is now opaque and its color is similar to what it would be if the original color was mixed with white, water is in the oil and it was mixed while the engine/transmission was operating. The oil can't actually mix with water, but it can emulsify. This is the same reason mayonnaise is thick and white- it's materials that don't mix, but can become suspended after being agitated vigorously.
You'll need to find where the water got in and repair that before flushing the transmission. Replacing the oil without running it won't take care of the problem- it needs to be run with new oil and you need to make sure no water remains.
Old 09-29-2013, 12:33 PM
Boat: 2001 x star
i did have waterbuild up in the bildge and was higher then my bildge pump. a ballast pump sleeve split on me. il take a picture of the dipstick and post it up. it dosent look like cafe-au-lait like some guys say it should. it may just be fresh oil and im just paranoid
Old 09-29-2013, 01:12 PM
Collect some and look at it- if it looks like new oil, it's OK but if it's cloudy, it has water in it.
