Old 05-14-2007, 10:28 AM
sizzler's Avatar
sizzler sizzler is offline
Boat: 1995 barefoot200;;;2004 X9 MCX
NYMAN problems
chaps.......gonna share my pain with you....when i lower or raise the lift it will only move for about 1 sec then shut off...i have to wait for another minute or so before trying again......it will only go for about a sec. at a time........battery is fine.........anyone had this problem before????
anyone know what the answer is....???
KEEP YA TOES UP!!!!!
2004 X9 MCX ALL BLACK
http://www.prwb.net/tallington/index.php?id=12
nice older x-boat at berth in the advertisment above
Old 05-14-2007, 10:33 AM
PendO's Avatar
PendO PendO is offline
Boat: 06 197 1.26:1 MCX (Gone but not forgotten)
are you using a remote or a hard wired controller?
At least you know one person who collected from the Cash Rewards program
Old 05-14-2007, 10:35 AM
sizzler's Avatar
the hard wire switch on the box
Old 05-14-2007, 11:15 AM
PendO's Avatar
there should be a way to rule out if it is a bad switch ... on our electric lift you can jump across two pins and operate the lift with a small piece of insulated wire ... but our controller plugs in, so I am not sure how you could do it if the switch is integrated into the board ... it sounds like there is an electrical short/bad ground wire ... is it hydraulic or an electric winch?
Old 05-14-2007, 11:31 AM
sizzler's Avatar
its hydraulic.........i shoulda got a picture but it was raining so hard.....took me 45 mins to get the lift up..........shoulda put some viagra in the oil.....
Old 05-14-2007, 11:15 PM
PendO's Avatar
was the rainstorm the first time it failed? (could it be a moisture issue causing an internal protection mechanism to deactivate itself?)
Old 05-15-2007, 04:48 AM
sizzler's Avatar
no..its been happenning for a while now.......
Old 05-15-2007, 11:20 AM
sizzler's Avatar
anyone????
Old 05-15-2007, 11:22 AM
PendO's Avatar
sorry man, I keep hoping someone smart will reply, otherwise I'm just bumping the thread back up top ... ours plugs into an gfci outlet receptacle (like the ones you have in your bathroom or kitchen b/c of moisture) ... so the receptacle has is own built in breaker, as well as the breaker at the main power pannel ... if it was wiring gone bad t would probably kick the breaker on the main pannel or the gfci outlet, if that is not happeneing then I think it has to be in the circuit board for the lift ... the goal (for me) would be to find a way to bypass the circuit board and operate the lift by knowing how to power the hydraulic pump ... we did have a circuit board go bad on our lift once ...
Old 05-15-2007, 11:25 AM
sizzler's Avatar
no probs.......i've e-mailed my dealer as well.......just thought someone may have had the same issues as i have.........
