Old 05-10-2007, 05:59 PM
32offer's Avatar
32offer 32offer is offline
Boat: 2002 Mastercraft Prostar 197
Question Prop question
I recently upgraded to a Prostar 197 from a '92 Prostar, so naturally I've got quite a bit more power. I went from 44mph to about 55 mph. I am going to need to get my prop repaired on the new ('02) boat. It is a 13" x 13" OJ S.S. 4-blade. I was thinking about changing sizes to maybe get better fuel economy with gas prices skyrocketing. I would even be ok loosing a little holeshot power, as I don't use anywhere near full throttle as it is. I primarily pull up 180 lb slalom skiers and barefooters.
Old 05-10-2007, 06:06 PM
dsoby's Avatar
dsoby dsoby is offline
Boat: 2002 X7, LTR
55? That's way faster than I've ever heard of a 197 going. 13X13 is the standard prop for a 1:1 transmision. Alot of folks are switching to an Acme 541 3 blade. It seems to be smother and quicker than the standard OJ 4 blade.
Old 05-10-2007, 11:12 PM
PendO's Avatar
PendO PendO is offline
Boat: 06 197 1.26:1 MCX (Gone but not forgotten)
http://www.waterskimag.com/product.j...clientID=17146
What engine do you have ... unless you have an 8.1L or some supercharger setup you need to verify your speed with GPS, as the LQ9 in a 2002 197 (pre-hook) ... will allegedly top out @ 47.2
boat Specifications:
Year2002Length Overall (Feet)19Length Overall (Inches)8Displacement2800Fuel Capacity28Load Capacity1340Seating Capacity10Acceleration to 36 MPH (seconds)6 seconds; 170.3 feetNoise at 36 MPH89 D 92 RNoise at Idle59 D 61 RTest EngineIndmar LQ-9 6.0L EFI 385hpTest Prop14 x 20 OJ 4-bladeTop Speed47.2
At least you know one person who collected from the Cash Rewards program
Old 05-11-2007, 08:56 AM
dsoby's Avatar
Boat: 2002 X7, LTR
The "pre-hooked" hull on this boat was a bit faster than the hooked version but only by about 1-2 MPH. I believe that I clocked mine at 50 on a GPS before hooking it.
Old 05-11-2007, 09:48 AM
3event's Avatar
3event 3event is offline
Boat: 2002 PS197
Wow, 55mph. How many hours, options, what engine? Maybe I'll trade you for my 02 with the Predator . I get 47.2mph with a 3blade 14pitch. Hull is stock, no hook added....yet. As for fuel economy, I have no idea - I just keep feeding her when she needs it. Summer's too short here to worry too much!
Check this thread for prop performance info....
http://www.tmcowners.com/teamtalk/sh...t=11251&page=3
2002 ProStar 197
Old 05-15-2007, 12:07 PM
32offer's Avatar
Well....at least that's what my speedo AND Perfect Pass are reading. I just bought the boat a couple weeks ago and haven't had it in the slalom course yet to time it or GPS'd it, so it could definitely be a little off. It feels a lot slower at 36 mph while skiing than my last Prostar did. So say it's off by 5-6 mph at 55mph, it would be a couple mph off at 36 mph.
Old 05-15-2007, 02:38 PM
dsoby's Avatar
Boat: 2002 X7, LTR
The speedo and the PP get their input from the same source (paddle wheel). You can calibrate the speedo and PP in the wakeboard mode with a GPS but I'm pretty sure that the slalom mode must be calibrated on a course using magnets or the smart timer.
Old 05-15-2007, 03:24 PM
#47of100TeamMC's Avatar
#47of100TeamMC #47of100TeamMC is offline
Boat: 2002 Tournament Team Edition Prostar 197
Send a message via MSN to #47of100TeamMC
I have a 2002 197 TT with LQ9 and Powerslot, Hooked hull Stock OJ 4 Blade. I'm seeing 52.8 on top end. 34.2 and 36 are verified in the course and GPS as spot on.
2002 ProStar197 Tournament Team Edition (yes it's Red)
*LQ9, Powerslot,Perfect Pass,Zero Flex tower,Heater
Old 05-15-2007, 03:51 PM
TRBenj TRBenj is offline
Boat: 1990 Ski Nautique
Did you verify the 52.8 on GPS?
The only reason I ask is because Ive set speedos in the course at slalom speeds with the smart timer, and PP is still off on the top end by ~3 MPH (reads 49, actually 46 according to GPS). One would think that calibrating the paddlewheel in the course would make it read correctly at all speeds, but it doesnt!
Old 05-15-2007, 03:56 PM
32offer's Avatar
What is this "hooked" hull everyone speaks of? Some sort of modification? What is the reason and what does it improve?
