Old 05-05-2007, 12:29 PM
Jesus_Freak's Avatar
Jesus_Freak Jesus_Freak is offline
Boat: Past: 1994 PS 205 --> Now: Nothing
Spacing of supports on boat lift?
I am trying to support a 94 PS 205 with a lift. How far apart should the supports under the hull be? The supports on my trailer are not parallel (ballpark ~36" spacing in the rear to ~24" spacing in the front). I am wondering how critical the lateral spacing is. I assume it is important to support the hull correctly. See the picture (not my boat or lift) and see how close these support beams are to the bottom of the vee. Suggestions?
Life is fragile; Pray hard (click for prayer requests)
"Magna opera Domini exquisita in omnes voluntates ejus" - James Clerk Maxwell, physics pioneer, 1874
Old 05-05-2007, 12:30 PM
Monte's Avatar
Monte Monte is offline
Boat: 1986 Tristar 220 351 pcm
JF, my suggestion woud be the same width as the bunks on your trailer, but I am no expert..
Old 05-05-2007, 08:47 PM
Thanks. I agree that this would be the most technically correct, but having them NOT parallel (like the trailer) will be much harder.
Come on peeps....I know you all have boat lifts AND prostars AND $0.02. Can you spare some advice?
Old 05-05-2007, 09:02 PM
Rich_G's Avatar
Rich_G Rich_G is offline
Boat: 99 205V
the main thing is that the bunks don't interfere with the thru-hull water intake, the Paddle Wheel if you have one or will put one it at some point.
I would match the width of the bunks at the rear of the trailer, and make them a little taller toward the front of the cradle. The trailer is designed to "drive on" and center the boat as it comes up the trailer. The lift just scoops up the boat from underneath. If you can, use some guide posts like in the pic above. I have mine where the lift cables act as guides. The go thru a PVC pipe where it catches the rub rail.
Old 05-05-2007, 11:19 PM
VTJC VTJC is offline
Boat: None
I matched my trailer as close as I could with my bunks. I would avoid things as Rich_G suggested. I think it’s most important to match the trailer under the heaviest parts of the boat. Jamie
08 Correct Craft Ski Nautique 196 343 HP 350 MPI EFI
Previous Boats:
99 MasterCraft SportStar CB 310 HP 350 TBI EFI
98 Moomba Boomerang 310 HP 350 Carb
88 MC PowerSlot 240 HP 351 Carb Black on White
Old 05-06-2007, 01:05 AM
SDAhockey21's Avatar
SDAhockey21 SDAhockey21 is offline
Boat: 2007 Saltwater Series X2
Send a message via AIM to SDAhockey21
In the picture, the only reason the bunks are so close together is because if they were any further apart, the hull would be resting on the lift's metal beams and not on the bunks.
Mastercraft's don't have this deep of a v so the bunks can be placed further apart. I would go with the trailer configuration, but keep in mind that the center of the hull will extend beneath the bunks, as will the fins prop etc. so you might have to place the bucks closer than they are on the trailer so the keel of the boat and shaft, prop, etc don't hit the metal lift beams
Shop Carolina WaterSports Online
www.4WAKE.com
Old 05-06-2007, 01:08 AM
and thats my $0.04!! lol
www.4WAKE.com
Old 05-06-2007, 01:11 AM
Here is East's boat on a lift
I Hope its ok that i used your picture east
www.4WAKE.com
Old 05-07-2007, 10:11 AM
Perfect! Thanks gentlemen!!!
So...ETS, what is the spacing and tilt on those supports?
Old 05-09-2007, 02:11 AM
east tx skier's Avatar
Boat: 1998 Ski Nautique
No idea. And I'm out of town for the rest of the week. Sorry.
Previous: 1993 Prostar 205
FAQ
Be kind. Have fun.
