Old 04-30-2007, 02:37 PM
PsychoatLarge's Avatar
PsychoatLarge PsychoatLarge is offline
Boat: Mastercraft, stars and stripes, 1975, Holman Moody 302
Test Firing on trailer
This is my first year with my 1975 MC Stars and Stripes . What is the best way to get water to the engine when test firing the boat dry while on the trailer?
Old 04-30-2007, 02:40 PM
88 PS190 88 PS190 is offline
I feel the best way is to remove the water intake hose where it connects to the thru hull fitting, then either make a connection for your garden hose, or take a 5 gallon bucket, place the intake hose and place it into the bucket, then take your garden hose and turn it on and run it into the bucket.
Start the boat, and it will suck water out of the bucket for you.
Which is quite helpful.
Old 04-30-2007, 03:22 PM
I like the sound of the 5 gal. bucket method, it will let me know that my impeller is sucking. Thanks
Old 05-01-2007, 04:38 PM
wakescene's Avatar
wakescene wakescene is offline
Boat: 2001 Maristar 210VRS, LTR 330HP, ZeroFlex Tower, KGB Ballast, PerfectPass Wakeboard Pro,
personally I think this is about the best method...http://www.boatersworld.com/product/357260074msk.htm
Been using one for about 3 years now, no problems and I boat in salt water so I enjoy the fact that I can flush the motor after every use but not have to pull the boat out of the water ever time.
Simple to install too.
Old 05-01-2007, 04:55 PM
Anyone know what size hose is on an MCX for the perko flush pro??
___________________________________________
Myself I'll live on the edge and surf without a helmet.
Old 05-02-2007, 12:48 PM
wakescene's Avatar
I would expect 1 1/8th. I'd pop the hose off and measure or look on the thru-hull pickup and see if there is a marking indicating the size. Perhaps a call to a dealer or Vonore might help as well. If your running a late model boat, I would go 1 1/8th.
Old 05-02-2007, 01:29 PM
M-Funf's Avatar
M-Funf M-Funf is offline
Boat: 1976 Mastercraft Stars & Stripes 351W
First, welcome to the board! The methods above will work fine for running the boat on the trailer. Just remember not to take it above idle...
Oh, and if you've got pics of that ol' S&S, please post some!!!!
M-Funf (a.k.a. Jeff)
Our '76 Stars & Stripes
Canis meus id comedit
Old 05-02-2007, 01:50 PM
Ryan's Avatar
Ryan Ryan is offline
Boat: 2007 SANTE 220
Why limit wet running to only idle? It would take forever to get up to running temp to get the thermostat to open up. Wouldn't it? Unless one has a tranny that slips and lets the prop spin - potential safety issue...?
Old 05-02-2007, 01:55 PM
jraben8 jraben8 is offline
Boat: 99 OB SportStar
Send a message via AIM to jraben8 Send a message via MSN to jraben8
It really doesn't take it that long to reach operating temp. Maybe 5-7 minutes. The more important thing to think about is allowing enough water to get inside the engine. Higher RPM's mean more water to cool.
The outside faucet pressure at my home is good but I don't know to what extent in regards to how much water is required to cool one of our blocks???
Old 05-02-2007, 01:59 PM
Ryan- if the air and, especially the water are not too cold, the thermostat will definitely open on the trailer.
I like running it on a bucket but 10 gallons is about the minimum I would use. If the water volume from the hose isn't sufficient, it'll suck the bucket dry. I just found a 55 gal blue plastic anti-freeze barrel for $4. Look around and I'm sure you can find something similar. 30 gal is a good size- not too big or too small.
